I have 128 GB sd card which is attached to this device. If i change the boot from sd card, does it decrease the performance ? or can i mount the sd card with the Jetson memory(eMMC).
Installing new packages (DL frameworks, docker, etc) will use the boot storage, which is 16GB. This boot storage its getting filled when i installed the Jetson OS + Jetson SDK components. So i couldn’t pull a docker image even. Is there any way to extend the boot storage by using the SD Card storage
