Hi, Thank for nvidia-sdk-manager, we can flash our jetson nano emmc and install nvidia-docker manually (due to the limited storage).
sudo apt install nvidia-docker2
Update docker daemon
sudo vim /etc/docker/daemon.json
Ensure that /etc/docker/daemon.json with the path to nvidia-container-runtime:
"runtimes": {
"nvidia": {
"path": "/usr/bin/nvidia-container-runtime",
"runtimeArgs": []
Make docker update the path:
sudo pkill -SIGHUP dockerd
Howerver, unlike jetson sd, we had some problems installing some libraries that needed cuda.
libcublas.so.10.2: cannot open shared object file: No such file or directory
I checked, there is size difference of folder cuda-10.2 between docker container emmc and sd
In container emmc: /usr/local/cuda-10.2 – 111mb
In container sd: /usr/local/cuda-10.2 – 2.6gb
Step to install cuda in emmc
sudo apt install cuda-toolkit-10.2
export PATH=/usr/local/cuda-10.2/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-10.2/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
Step to run docker container:
nvidia-docker run -it -d --runtime nvidia --restart=always --net=host nvcr.io/nvidia/deepstream-l4t:5.1-21.02-samples
Therefore, I think this is an issue related to the nvidia runtime of the container. Look forward to the help.
Have you tried to launch it with docker directly?
For example:
$sudo docker run -it --rm --net=host --runtime nvidia ...
Hi @AastaLLL Thank for your response.
nvidia-docker run -it --runtime nvidia --restart=always --name fr_prod --net=host nvcr.io/nvidia/deepstream-l4t:5.1-21.02-samples
root@wesmart-desktop:/opt/nvidia/deepstream/deepstream-5.1# du -sh /usr/local/cuda
0 /usr/local/cuda
root@wesmart-desktop:/opt/nvidia/deepstream/deepstream-5.1# du -sh /usr/local/cuda-10.2/
111M /usr/local/cuda-10.2/
The result is still the same
Which JetPack do you use?
Since Deepstream 5.1 depends on the JetPack 4.5.1 which is released for a while.
If you are using a newer JetPack version, could you upgrade to the corresponding Deepstream instead?
Hi @AastaLLL Sorry for my lack of information.
Jetson nano Emmc 16gb (4gb ram).
Deepstream 5.1 is released for a while.
Would you mind upgrading your environment to Deepstream 6.0 + JetPack 4.6.1 and giving it a try?
The file size looks good within the deepstream-l4t:6.0.1-base container:
$ sudo docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.0 -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream-l4t:6.0.1-base
$ du -s -h /usr/local/cuda-10.2/
2.9G /usr/local/cuda-10.2/
Hi, Thank for your information.
It is considered a bug of ds5.1, if possible, we will plan to upgrade our project to 6.0.1/6.1.
