What options do you have when using docker with jetson nano(emmc) and running out of capacity?
Thank you.
Thank you.
Please check if the below comment helps:
When I run docker, the storage capacity of emmc becomes 0 and I cannot run it. How to solve this problem?
Thank you.
Do you mean eMMC memory fills up the partition? If you know where the content is saved, then you can temporarily mount external memory to that location. An example would be an external USB hard drive. A lot depends on what your particular case needs, e.g., maybe this is mobile and has no way of using an external drive. You’d need to describe more about your use case.
