When installing docker I’m getting this message and can’t continue:
“docker: Error response from daemon: error gathering device information while adding custom device “/dev/video0”: no such file or directory.”
I created docker_dli_run.sh as described but after donlowding a bunch of files sends that message. When repeat is the same.
I’m testing with two of them. Both gave same problem. I solved by booting Jetson. But now I got access to Jupyter and connection with CSI camera worked once, later when I execute python connection command all Jupyter crashes and server is disconnected. I tryed both options mentioned at tutorial. Add “–volume /tmp/argus_socket:/tmp/argus_socket” instruction (wich was the option that helped to work once) and incrementing swap memory and rebooting also. Always server connection crashes. What could be now?.
