Hello everyone;
I recently bought a new laptop with integrated AMD graphics and a dedicated Nvidia GTX 1050 card. However, after installing Kubuntu 19:10 on it I’ve been having a lot of problems. It seems the computer doesn’t want to load the driver for some reason, and the nvidia-settings command gives an empty window and the following message in the console:
(nvidia-settings:3354): GLib-GObject-CRITICAL **: 19:16:57.648: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 19:16:57.651: PRIME: No offloading required. Abort
** Message: 19:16:57.651: PRIME: is it supported? no
I have been trying to make it work but I just can’t; I’ve purged and reinstalled the drivers several times to no avail, even the operating system itself. It just does not want to work; I believe the computer doesnt load the drivers. I disabled secure boot on BIOS, as I read somewhere, but it still won’t work. It only uses the integrated graphics, while ignoring the dedicated card completely. Said card, however, does show up when prompted:
$ sudo lshw -c video
[sudo] password for jorge:
*-display
description: VGA compatible controller
product: GP107M [GeForce GTX 1050 3 GB Max-Q]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:53 memory:f6000000-f6ffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:f000(size=128) memory:f7000000-f707ffff
*-display
product: Picasso
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:05:00.0
version: c2
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix vga_controller bus_master cap_list rom
configuration: driver=amdgpu latency=0
resources: irq:62 memory:e0000000-efffffff memory:f0000000-f01fffff ioport:c000(size=256) memory:f7500000-f757ffff memory:c0000-dffff
I am using the nvidia 435 drivers, as recommended by ubuntu-drivers devices:
$ dkms status
nvidia, 435.21, 5.3.0-18-generic, x86_64: installed
nvidia, 435.21, 5.3.0-26-generic, x86_64: installed
Any help would be greatly appreciated.
nvidia-bug-report.log.gz (273 KB)
