I have a ASUS FX505DT with Ryzen 7 3750H and GTX1650 graphics card. I did a fresh Ubuntu 19.10 install. I selected installation of graphics drivers during os installation. Currently nvidia-driver-435 is installed.
It seems I cannot switch to NVIDIA card. When I run nvidia-settings I get a small blank screen. Below you can find some relevant outputs.
nvidia-settings
ERROR: Unable to load info from any available system
(nvidia-settings:9469): GLib-GObject-CRITICAL **: 21:29:58.118: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 21:29:58.121: PRIME: No offloading required. Abort
** Message: 21:29:58.121: PRIME: is it supported? no
uname -a
Linux asus 5.3.0-26-generic #28-Ubuntu SMP Wed Dec 18 05:37:46 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x54 cap: 0x9, Source Output, Sink Offload crtcs: 4 outputs: 1 associated providers: 0 name:Unknown AMD Radeon GPU @ pci:0000:05:00.0
nvidia-smi
Thu Jan 16 21:34:03 2020
| NVIDIA-SMI 435.21 Driver Version: 435.21 CUDA Version: 10.1 |
| 0 GeForce GTX 1650 Off | 00000000:01:00.0 Off | N/A |
| N/A 39C P0 3W / N/A | 0MiB / 3911MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
prime-select query
nvidia
nvidia-bug-report.log
https://paste.ubuntu.com/p/yj9ByF9RDn/
Thank you in advance.
