Enable ECC on RTX 4090 on Ubuntu 22.04 LTS
Trying to enable ECC on an RTX 4090 running on Ubuntu 22.04.
  • Can not turn ECC on using the nvidia-settings GUI
  • Toggling ECC via the CLI sudo nvidia-smi -e=1 returns the response that a reboot is required. After reboot, nvidia-settings doesn’t show the card, but the display is working. A shutdown & restart (cold boot) returns the card to be “seen” with the nvidia-settings GUI, but ECC isn’t enabled.
$ nvidia-smi -q
==============NVSMI LOG==============
Timestamp : Thu Aug 10 15:36:21 2023
Driver Version : 535.86.10
CUDA Version : 12.2
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : NVIDIA GeForce RTX 4090
Product Brand : GeForce
Product Architecture : Ada Lovelace
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : Enabled
Addressing Mode : None
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-9872cbec-3e30-d2d9-5e19-25fcda8b67f9
Minor Number : 0
VBIOS Version : 95.02.3C.00.4E
MultiGPU Board : No
Board ID : 0x100
Board Part Number : N/A
GPU Part Number : 2684-300-A1
FRU Part Number : N/A
Module ID : 1
Inforom Version
Image Version : G002.0000.00.03
OEM Object : 2.0
ECC Object : 6.16
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GSP Firmware Version : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
GPU Reset Status
Reset Required : No
Drain and Reset Recommended : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x268410DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x13B3196E
GPU Link Info
PCIe Generation
Max : 4
Current : 1
Device Current : 1
Device Max : 4
Host Max : 4
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 1000 KB/s
Rx Throughput : 0 KB/s
Atomic Caps Inbound : N/A
Atomic Caps Outbound : N/A
Fan Speed : 0 %
Performance State : P8
Clocks Event Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 24564 MiB
Reserved : 355 MiB
Used : 747 MiB
Free : 23460 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 17 MiB
Free : 239 MiB
Conf Compute Protected Memory Usage
Total : 0 MiB
Used : 0 MiB
Free : 0 MiB
Compute Mode : Default
Utilization
Gpu : 7 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
JPEG : 0 %
OFA : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
ECC Mode
Current : Disabled
Pending : Disabled
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows
Correctable Error : 0
Uncorrectable Error : 0
Pending : No
Remapping Failure Occurred : No
Bank Remap Availability Histogram
Max : 192 bank(s)
High : 0 bank(s)
Partial : 0 bank(s)
Low : 0 bank(s)
None : 0 bank(s)
Temperature
GPU Current Temp : 47 C
GPU T.Limit Temp : 36 C
GPU Shutdown T.Limit Temp : -7 C
GPU Slowdown T.Limit Temp : -2 C
GPU Max Operating T.Limit Temp : 0 C
GPU Target Temperature : 84 C
Memory Current Temp : N/A
Memory Max Operating T.Limit Temp : N/A
GPU Power Readings
Power Draw : 13.89 W
Current Power Limit : 450.00 W
Requested Power Limit : 450.00 W
Default Power Limit : 450.00 W
Min Power Limit : 150.00 W
Max Power Limit : 450.00 W
Module Power Readings
Power Draw : N/A
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : 210 MHz
SM : 210 MHz
Memory : 405 MHz
Video : 1185 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 3105 MHz
SM : 3105 MHz
Memory : 10501 MHz
Video : 2415 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : 875.000 mV
Fabric
State : N/A
Status : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 2680
Type : G
Used GPU Memory : 94 MiB
Process ID : 2847
Type : C+G
Used GPU Memory : 390 MiB
Process ID : 2884
Type : G
Used GPU Memory : 69 MiB
Process ID : 4488
Type : G
Used GPU Memory : 164 MiB
You can use nvidia-settings,it works.
Hi @andorjkiss, Are you able to disable ECC? I am facing the same problem.
Yes, I was able to enable and disable ECC RAM on the GPU after the next driver update - guess there was a bug in the initial driver that required sudo permissions for that option. Using the lastest nVIDIA Linux driver currently (545.x).
