I have confirmed that the MLNX OFED Driver version 23.04-0.5.3.3 supports “Multiport E-Switch”.
If Multiport E-Switch is supported, it seems possible to bundle one port from each of the two NICs into VF-LAG.
Is that correct?
Is that correct?
No, e-switch on same NIC only, if multi NIC need SW switch in theory.
The multiport eSwitch mode allows to add rules on a VF representor with an action forwarding the packet to the physical port of the physical function.
