Error 304.107 installing on RHEL 7.7 invalid kernel config
I am attempting to create a 340.107-custom.run for a RHEL 7.7 kickstart. When I run the add this kernel command I am getting an “ERROR: Unable to build the NVIDIA kernel module interface” and “ERROR: Unable to add a precompiled kernel interface for the running kernel”. In the /var/log/nvidida-installer.log I am getting an Error for Kernel Configuration is invalid. Any ideas what the issue could be?
RHEL 7.7
Kernel - 3.10.0-1062.el7.x86_64
Video Card - Nvidia Quadro FX 580
Nvidia Driver - NVIDIA-Linux-x86_64-340.107.run
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Mon Sep 23 03:20:15 2019
installer version: 340.107
PATH: /usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin
nvidia-installer command line:
    ./nvidia-installer
    --add-this-kernel
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
-> Tagging shared libraries with chcon -t textrel_shlib_t.
-> Performing CC sanity check with CC="/bin/cc".
-> Kernel source path: '/lib/modules/3.10.0-1062.el7.x86_64/source'
-> Kernel output path: '/lib/modules/3.10.0-1062.el7.x86_64/build'
-> Copying kernel module sources to temporary directory.
-> Building kernel module interface:
   executing: 'cd /tmp/nvidia-2567/; /bin/make nv-linux.o SYSSRC=/lib/modules/3.10.0-1062.el7.x86_64/source SYSOUT=/lib/modules/3.10.0-1062.el7.x86_64/build NV_MODULE_SUFFIX='...
   NVIDIA: calling KBUILD...
   make[1]: Entering directory `/usr/src/kernels/3.10.0-1062.el7.x86_64'
   /bin/make -C /lib/modules/3.10.0-1062.el7.x86_64/build \
   KBUILD_SRC=/usr/src/kernels/3.10.0-1062.el7.x86_64 \
   KBUILD_EXTMOD="/tmp/nvidia-2567" -f /usr/src/kernels/3.10.0-1062.el7.x86_64/Makefile \
   modules
   test -e include/generated/autoconf.h -a -e include/config/auto.conf || (		\
   echo >&2;							\
   echo >&2 "  ERROR: Kernel configuration is invalid.";		\
   echo >&2 "         include/generated/autoconf.h or include/config/auto.conf are missing.";\
   echo >&2 "         Run 'make oldconfig && make prepare' on kernel src to fix it.";	\
   echo >&2 ;							\
   /bin/false)
   mkdir -p /tmp/nvidia-2567/.tmp_versions ; rm -f /tmp/nvidia-2567/.tmp_versions/*
   /bin/make -f /usr/src/kernels/3.10.0-1062.el7.x86_64/scripts/Makefile.build obj=/tmp/nvidia-2567
     cc -Wp,-MD,/tmp/nvidia-2567/.nv.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include -Iarch/x86/include/generated  -I/usr/src/kernels/3.10.0-1062.el7.x86_64/include -Iinclude -I/usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/kernels/3.10.0-1062.el7.x86_64/include/uapi -Iinclude/generated/uapi -include /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/kconfig.h   -I/tmp/nvidia-2567 -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -Wframe-larger-than=2048 -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -mindirect
   -branch=thunk-extern -mindirect-branch-register -DRETPOLINE -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -mfentry -DCC_USING_FENTRY -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG   -I/tmp/nvidia-2567 -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"340.107\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=\"nvidia\"  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/nvidia-2567/.tmp_nv.o /tmp/nvidia-2567/nv.c
   In file included from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/byteorder/little_endian.h:6:0,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/uapi/asm/byteorder.h:4,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/asm-generic/bitops/le.h:5,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/asm/bitops.h:514,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/bitops.h:37,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/kernel.h:10,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/sched.h:15,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/utsname.h:5,
                    from /tmp/nvidia-2567/nv-linux.h:44,
                    from /tmp/nvidia-2567/nv.c:13:
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/byteorder/generic.h: In function ‘cpu_to_be32_array’:
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/byteorder/generic.h:177:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
     for (i = 0; i < len; i++)
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/byteorder/generic.h: In function ‘be32_to_cpu_array’:
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/byteorder/generic.h:185:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
   In file included from /usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/asm/cpumask.h:4:0,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/asm/msr.h:10,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/asm/processor.h:20,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/asm/cpufeature.h:7,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/asm/thread_info.h:22,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/thread_info.h:66,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/preempt.h:9,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/spinlock.h:50,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/seqlock.h:35,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/time.h:5,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/uapi/linux/timex.h:56,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/timex.h:56,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/sched.h:17,
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/cpumask.h: In function ‘cpumask_parse’:
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/cpumask.h:634:26: warning: signed and unsigned type in conditional expression [-Wsign-compare]
     int len = nl ? nl - buf : strlen(buf);
   In file included from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/rh_kabi.h:22:0,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/sched.h:5,
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/asm-generic/qrwlock.h: In function ‘queued_write_trylock’:
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/asm-generic/qrwlock.h:93:35: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
             cnts, cnts | _QW_LOCKED) == cnts);
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’
    # define likely(x) __builtin_expect(!!(x), 1)
   In file included from /tmp/nvidia-2567/nv-linux.h:91:0,
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/cpufreq.h: In function ‘cpufreq_next_valid’:
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/cpufreq.h:534:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
     while ((*pos)->frequency != CPUFREQ_TABLE_END)
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/cpufreq.h:535:25: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
      if ((*pos)->frequency != CPUFREQ_ENTRY_INVALID)
   /usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_from_user’:
   /usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/asm/uaccess_64.h:78:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
     if (likely(sz == -1 || sz >= n)) {
   /usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_to_user’:
   /usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/asm/uaccess_64.h:95:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
     if (likely(sz == -1 || sz >= size)) {
     if [ "-pg" = "-pg" ]; then if [ /tmp/nvidia-2567/nv.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount  "/tmp/nvidia-2567/nv.o"; fi; fi;
     cc -Wp,-MD,/tmp/nvidia-2567/.nv-acpi.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include -Iarch/x86/include/generated  -I/usr/src/kernels/3.10.0-1062.el7.x86_64/include -Iinclude -I/usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/kernels/3.10.0-1062.el7.x86_64/include/uapi -Iinclude/generated/uapi -include /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/kconfig.h   -I/tmp/nvidia-2567 -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args
    -Wframe-larger-than=2048 -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -mindirect-branch=thunk-extern -mindirect-branch-register -DRETPOLINE -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -mfentry -DCC_USING_FENTRY -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG   -I/tmp/nvidia-2567 -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"340.107\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D
   __linux__ -DNV_DEV_NAME=\"nvidia\"  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_acpi)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/nvidia-2567/.tmp_nv-acpi.o /tmp/nvidia-2567/nv-acpi.c
                    from /tmp/nvidia-2567/nv-acpi.c:15:
     if [ "-pg" = "-pg" ]; then if [ /tmp/nvidia-2567/nv-acpi.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount  "/tmp/nvidia-2567/nv-acpi.o"; fi; fi;
     cc -Wp,-MD,/tmp/nvidia-2567/.nv-chrdev.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include -Iarch/x86/include/generated  -I/usr/src/kernels/3.10.0-1062.el7.x86_64/include -Iinclude -I/usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/kernels/3.10.0-1062.el7.x86_64/include/uapi -Iinclude/generated/uapi -include /usr/src/kernels/3.10.0-1062.el7
   .x86_64/include/linux/kconfig.h   -I/tmp/nvidia-2567 -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -Wframe-larger-than=2048 -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -mindirect-branch=thunk-extern -mindirect-branch-register -DRETPOLINE -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -mfentry -DCC_USING_FENTRY -fno-inline-functions-called-once -Wdeclaration-after-statement
    -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG   -I/tmp/nvidia-2567 -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"340.107\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=\"nvidia\"  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_chrdev)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/nvidia-2567/.tmp_nv-chrdev.o /tmp/nvidia-2567/nv-chrdev.c
                    from /tmp/nvidia-2567/nv-chrdev.c:15:
     if [ "-pg" = "-pg" ]; then if [ /tmp/nvidia-2567/nv-chrdev.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount  "/tmp/nvidia-2567/nv-chrdev.o"; fi; fi;
     cc -Wp,-MD,/tmp/nvidia-2567/.nv-cray.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include -Iarch/x86/include/generated  -I/usr/src/kernels/3.10.0-1062.el7.x86_64/include -Iinclude -I/usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/kernels/3.10.0-1062.el7.x86_64/include/uapi -Iinclude/generated/uapi -include /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/kconfig.h   -I/tmp/nvidia-2567 -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -Wframe-larger-than=2048 -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SH
   A256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -mindirect-branch=thunk-extern -mindirect-branch-register -DRETPOLINE -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -mfentry -DCC_USING_FENTRY -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG   -I/tmp/nvidia-2567 -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"340.107\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=\"nvidia\"  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_cray)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/nvidia-2567/.tmp_nv-cray.o /tmp/nvidia-2567/nv-cray.c
                    from /tmp/nvidia-2567/nv-cray.c:15:
     if [ "-pg" = "-pg" ]; then if [ /tmp/nvidia-2567/nv-cray.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount  "/tmp/nvidia-2567/nv-cray.o"; fi; fi;
     cc -Wp,-MD,/tmp/nvidia-2567/.nv-dma.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include -Iarch/x86/include/generated  -I/usr/src/kernels/3.10.0-1062.el7.x86_64/include -Iinclude -I/usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/kernels/3.10.0-1062.el7.x86_64/include/uapi -Iinclude/generated/uapi -include /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/kconfig.h   -I/tmp/nvidia-2567 -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-nu
   ll-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -Wframe-larger-than=2048 -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -mindirect-branch=thunk-extern -mindirect-branch-register -DRETPOLINE -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -mfentry -DCC_USING_FENTRY -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG   -I/tmp/nvidia-2567 -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-
   error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"340.107\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=\"nvidia\"  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_dma)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/nvidia-2567/.tmp_nv-dma.o /tmp/nvidia-2567/nv-dma.c
                    from /tmp/nvidia-2567/nv-dma.c:15:
     if [ "-pg" = "-pg" ]; then if [ /tmp/nvidia-2567/nv-dma.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount  "/tmp/nvidia-2567/nv-dma.o"; fi; fi;
     cc -Wp,-MD,/tmp/nvidia-2567/.nv-drm.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include -Iarch/x86/include/generated  -I/usr/src/kernels/3.10.0-1062.el7.x86_64/include -Iinclude -I/usr/src/kernels/3.10.0-1062.el7.x86_64/arch/x86/include/
   uapi -Iarch/x86/include/generated/uapi -I/usr/src/kernels/3.10.0-1062.el7.x86_64/include/uapi -Iinclude/generated/uapi -include /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/kconfig.h   -I/tmp/nvidia-2567 -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -Wframe-larger-than=2048 -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -mindirect-branch=thunk-extern -mindirect-branch-register -DRETPOLINE -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-se
   t-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -mfentry -DCC_USING_FENTRY -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG   -I/tmp/nvidia-2567 -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"340.107\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=\"nvidia\"  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_drm)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/nvidia-2567/.tmp_nv-drm.o /tmp/nvidia-2567/nv-drm.c
                    from /tmp/nvidia-2567/nv-drm.c:15:
   In file included from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/drm/drm_crtc.h:31:0,
                    from /usr/src/kernels/3.10.0-1062.el7.x86_64/include/drm/drmP.h:69,
                    from /tmp/nvidia-2567/nv-drm.c:19:
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/fb.h: In function ‘__fb_pad_aligned_buffer’:
   /usr/src/kernels/3.10.0-1062.el7.x86_64/include/linux/fb.h:651:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
      for (j = 0; j < s_pitch; j++)
   /tmp/nvidia-2567/nv-drm.c: In function ‘nv_alloc_os_descriptor_handle’:
   /tmp/nvidia-2567/nv-drm.c:255:5: error: implicit declaration of function ‘drm_gem_object_unreference_unlocked’ [-Werror=implicit-function-declaration]
        drm_gem_object_unreference_unlocked(&nv_obj->base);
   cc1: some warnings being treated as errors
   make[3]: *** [/tmp/nvidia-2567/nv-drm.o] Error 1
   make[2]: *** [_module_/tmp/nvidia-2567] Error 2
   make[1]: *** [sub-make] Error 2
   make[1]: Leaving directory `/usr/src/kernels/3.10.0-1062.el7.x86_64'
   NVIDIA: left KBUILD.
   nvidia.ko failed to build!
   make: *** [nvidia.ko] Error 1
-> Error.
ERROR: Unable to build the NVIDIA kernel module interface.
ERROR: Unable to add a precompiled kernel interface for the running kernel.
You are misreading the output. There is no kernel configuration error. But 340.107 needs to be patched for the 7.7 kernel. Patches can be found in this forum.
But you shouldn’t use the run file. Use a packaged version of the driver like the one here:
Thank you Chemal! That fixed the issue and we will be using that resource in the future for our nvidia drivers.
