Hi, per the “Omniverse DSX Blueprint” Quickstart guide, I downloaded the USD model (DSX_BP.zip) from NGC using CLI. The file downloads successfully, but when I try to extract/upack the zip file I get error “The compressed (zipped) folder ‘C:xxxx\DSX_BP.zip is invalid”. I am running windows on local workstation.
Hi and thanks for posting. This is strange. The only thing I can think of is that the zip file got corrupted during download. I am sure the master zip file is ok. Can you send me the exact link? Can you try to download through the website, normally, not the CLI?
Thanks for the timely response. The link is: link. I will tried direct download and get the same error.
I’m going to attempt to download it right now and see if it fails or not. But just one thing. I see that it requires the Nvidia CLI downloader to be installed first. I’m assuming you’ve already installed that correct?
I downloaded it with the CLI command and it downloaded fine. Then I used “7Zip” to unzip it and it unzipped fine.
HOWEVER, with regular Windows Zip (Extract All) The zip file fails, yes. We always use 7zip at work. Let me find out why it fails with normal windows zip.
I was able to unzip with winrar. Thanks for your support.
You are welcome! Sorry about that. We will get it fixed.
