I am following this turtorial for flashing my jetson orin nx:
When I run the last command to flash the OS i get the error:
Board ID(3767) version(500) sku(0000) revision()
Preset RAMCODE is 1
Chip SKU(00:00:00:D3) ramcode(1) fuselevel(fuselevel_production) board_FAB(500)
emc_opt_disable_fuse:(0)
Error: missing cfgfile ().
Usage: sudo ./flash.sh [options] generic external
options:
-c --------
--generic-passphrase -- Use generic passphrase for disk encryption.
--disable-random-iv --- Disable generation of random IV, SALT1, SALT2 and DERSTR.
--read-info ----------- Read and display board related info, fuse info (based on fuse_t234.xml),
and EEPROM content.
--reuse-uuid --------- Reuse uuid which is already generated first time.
--qspi-only --------- Flash QSPI device only.
--gen-rcmdump -------- Generate rcmdump_blob
Error: failed to generate images
Cleaning up…
