Hello. I’m just trying to install Jetpack2.3.1 on TetsonTX1.
But installer shows me some error message as below and stopped working.
Err:13 Index of /ubuntu-ports xenial/main Sources
Cannot initiate the connection to ports.ubuntu.com:80 (2001:67c:1360:8001::22). - connect (101: Network is unreachable) [IP: 2001:67c:1360:8001::22 80]
Err:41 Index of /ubuntu-ports xenial-updates/main Sources
Err:69 Index of /ubuntu-ports xenial-backports/main arm64 Packages
Err:93 Index of /ubuntu-ports xenial-security/main Sources
dpkg-query: package ‘cuda-toolkit-8-0’ is not installed and no information is available
dpkg-query: package ‘libfreeimage-dev’ is not installed and no information is available
dpkg-query: package ‘libopenmpi-dev’ is not installed and no information is available
dpkg-query: package ‘openmpi-bin’ is not installed and no information is available
Use dpkg --info (= dpkg-deb --info) to examine archive files,
and dpkg --contents (= dpkg-deb --contents) to list their contents.
1
Error: CUDA cannot be installed on device. This may be caused by other apt-get command running on device when installing CUDA. Please use apt-get command in a terminal to make sure following packages are installed correctly on device before continuing:
cuda-toolkit-8-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin
After these packages are installed on device, press Enter key to continue
Do someone know how to cope with this issue?
