Error instaling VisionWorks via SDK Manager. JetPack version 4.5.1
Issue
Installing VisionWorks fails. JetPack 4.5.1, latest SDK Manager
Error
10:23:07 ERROR: VisionWorks on Host - host: [error]: unarchive the package failure: reading file in zip archive: /home/raff/nvidia/nvidia_sdk/JetPack_4.5.1_Linux/documentations/VisionWorks/index.html: creating new file: open /home/raff/nvidia/nvidia_sdk/JetPack_4.5.1_Linux/documentations/VisionWorks/index.html: permission denied
10:23:07 ERROR: VisionWorks on Host - host: command terminated with error
Fix
  1. Change permission of the file, eg:
    sudo chmod 664 /home/raff/nvidia/nvidia_sdk/JetPack_4.5.1_Linux/documentations/VisionWorks/index.html
  2. Retry
Root Cause
The permissions on the file inside the zip package is incorrect (read only, or mode 444)
Hi raff,
Please try change below folder owner and check again.
$ sudo chown <username:username> JetPack_4.5.1_Linux
Thanks @carolyuu, but that doesn’t work. The problem isn’t file ownership, it’s file permission, and it’s only on the index.html file which is read-only. If you check my original post, I already have a fix. The purpose of the post is to draw attention to the issue so that:
  1. It can be fixed in the next version of the package
  2. Googling the error message will find this solution
