I guess the issue is due to you write the emmc based board sku to the eeprom.
So that the plugin-manager here modifies your dts.
[ 0.407690] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[ 0.408240] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[ 0.408705] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[ 0.409484] node /plugin-manager/fragement@7 match with odm-data enable-pmict
[ 0.409731] node /plugin-manager/fragement@8 match with odm-data enable-pmict
[ 0.410346] node /plugin-manager/fragement@10 match with board >=3448-0002-30
[ 0.412333] node /plugin-manager/fragement@13 match with board >=3448-0002-30
I don’t see above log in my boot up log.
A method here is you can disable those fragment in hardware/nvidia/platform/t210/porg/kernel-dts/porg-plugin-manager/tegra210-porg-plugin-manager.dtsi.
Rebuild the dtb and put it during your flash process. I guess the key is fragment@3 because it disables your sdhci controller so sdcard is not able to get run.
