here is the log without the “quiet”
[0000.075] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.080] Processing in cold boot mode Bootloader 2
[0000.085] A02 Bootrom Patch rev = 1023
[0000.088] Power-up reason: pmc por
[0000.092] No Battery Present
[0000.094] pmic max77620 reset reason
[0000.098] pmic max77620 NVERC : 0x40
[0000.101] RamCode = 0
[0000.103] Platform has DDR4 type RAM
[0000.107] max77620 disabling SD1 Remote Sense
[0000.111] Setting DDR voltage to 1125mv
[0000.115] Serial Number of Pmic Max77663: 0x1201ac
[0000.122] Entering ramdump check
[0000.125] Get RamDumpCarveOut = 0x0
[0000.129] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.134] Last reboot was clean, booting normally!
[0000.138] Sdram initialization is successful
[0000.143] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.149] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.154] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.160] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.166] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.172] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.178] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.184] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.200] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.206] Platform-DebugCarveout: 0
[0000.209] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.215] Non secure mode, and RB not enabled.
[0000.219] BoardID = 3448, SKU = 0x0
[0000.223] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.226] Nano-SD: checking PT table on QSPI …
[0000.231] Read PT from (2:0)
[0000.246] Using BFS PT to query partitions
[0000.252] Loading Tboot-CPU binary
[0000.280] Verifying TBC in OdmNonSecureSBK mode
[0000.290] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.297] Bootloader downloaded successfully.
[0000.301] Downloaded Tboot-CPU binary to 0xa0000258
[0000.306] MAX77620_GPIO5 configured
[0000.309] CPU power rail is up
[0000.312] CPU clock enabled
[0000.316] Performing RAM repair
[0000.319] Updating A64 Warmreset Address to 0xa00002e9
[0000.324] BoardID = 3448, SKU = 0x0
[0000.327] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.331] Nano-SD: checking PT table on QSPI …
[0000.336] Loading NvTbootBootloaderDTB
[0000.402] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.475] Bootloader DTB Load Address: 0x83000000
[0000.480] BoardID = 3448, SKU = 0x0
[0000.483] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.487] Nano-SD: checking PT table on QSPI …
[0000.491] Loading NvTbootKernelDTB
[0000.557] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.630] Kernel DTB Load Address: 0x83100000
[0000.635] BoardID = 3448, SKU = 0x0
[0000.638] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.642] Nano-SD: checking PT table on QSPI …
[0000.648] Loading cboot binary
[0000.764] Verifying EBT in OdmNonSecureSBK mode
[0000.805] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.812] Bootloader downloaded successfully.
[0000.817] BoardID = 3448, SKU = 0x0
[0000.820] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.824] Nano-SD: checking PT table on QSPI …
[0000.828] PT: Partition NCT NOT found !
[0000.832] Warning: Find Partition via PT Failed
[0000.836] Next binary entry address: 0x92c00258
[0000.841] BoardId: 3448
[0000.846] BoardID = 3448, SKU = 0x0
[0000.849] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.853] Nano-SD: checking PT table on QSPI …
[0000.958] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.014] /bpmp deleted
[0001.017] SC7EntryFw header found loaded at 0xff700000
[0001.212] OVR2 PMIC
[0001.214] Bpmp FW successfully loaded
[0001.217] BoardID = 3448, SKU = 0x0
[0001.221] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.224] Nano-SD: checking PT table on QSPI …
[0001.230] WB0 init successfully at 0xff780000
[0001.234] Set NvDecSticky Bits
[0001.238] GSC2 address ff53fffc value c0edbbcc
[0001.244] GSC MC Settings done
[0001.247] BoardID = 3448, SKU = 0x0
[0001.250] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.254] Nano-SD: checking PT table on QSPI …
[0001.259] TOS Image length 53680
[0001.262] Monitor size 53680
[0001.265] OS size 0
[0001.280] Secure Os AES-CMAC Verification Success!
[0001.285] TOS image cipher info: plaintext
[0001.289] Loading and Validation of Secure OS Successful
[0001.305] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.309] NvTbootPackSdramParams: start.
[0001.314] NvTbootPackSdramParams: done.
[0001.318] Tegraboot started after 51831 us
[0001.322] Basic modules init took 826430 us
[0001.326] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.332] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.337] Next stage binary read took 102860 us
[0001.341] Carveout took -117347 us
[0001.345] CPU initialization took 486370 us
[0001.349] Total time taken by TegraBoot 1298313 us
[0001.353] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:37:40, Feb 19 2021
ERROR: Error initializing runtime service trusty_fast
[0001.476] RamCode = 0
[0001.480] LPDDR4 Training: Read DT: Number of tables = 2
[0001.485] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.498] EMC Training Successful
[0001.501] 408000 not found in DVFS table
[0001.508] RamCode = 0
[0001.511] DT Write: emc-table@204000 succeeded
[0001.517] DT Write: emc-table@1600000 succeeded
[0001.521] LPDDR4 Training: Write DT: Number of tables = 2
[0001.566]
[0001.567] Debug Init done
[0001.570] Marked DTB cacheable
[0001.573] Bootloader DTB loaded at 0x83000000
[0001.578] Marked DTB cacheable
[0001.580] Kernel DTB loaded at 0x83100000
[0001.584] DeviceTree Init done
[0001.597] Pinmux applied successfully
[0001.602] gicd_base: 0x50041000
[0001.605] gicc_base: 0x50042000
[0001.608] Interrupts Init done
[0001.612] Using base:0x60005090 & irq:208 for tick-timer
[0001.618] Using base:0x60005098 for delay-timer
[0001.622] platform_init_timer: DONE
[0001.625] Timer(tick) Init done
[0001.629] osc freq = 38400 khz
[0001.633]
[0001.634] Welcome to L4T Cboot
[0001.637]
[0001.638] Cboot Version: 00.00.2018.01-t210-39562017
[0001.643] calling constructors
[0001.646] initializing heap
[0001.649] initializing threads
[0001.652] initializing timers
[0001.655] creating bootstrap completion thread
[0001.659] top of bootstrap2()
[0001.662] CPU: ARM Cortex A57
[0001.665] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.670] initializing platform
[0001.677] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.682] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.686] Macronix QSPI chip present
[0001.690] SPI device register
[0001.692] init boot device
[0001.695] allocating memory for boot device(SPI)
[0001.700] registering boot device
[0001.708] QSPI bdev is already initialized
[0001.712] Enable APE clock
[0001.715] Un-powergate APE partition
[0001.718] of_register: registering tegra_udc to of_hal
[0001.723] of_register: registering inv20628-driver to of_hal
[0001.729] of_register: registering ads1015-driver to of_hal
[0001.734] of_register: registering lp8557-bl-driver to of_hal
[0001.740] of_register: registering bq2419x_charger to of_hal
[0001.746] of_register: registering bq27441_fuel_gauge to of_hal
[0001.757] gpio framework initialized
[0001.761] of_register: registering tca9539_gpio to of_hal
[0001.766] of_register: registering tca9539_gpio to of_hal
[0001.771] of_register: registering i2c_bus_driver to of_hal
[0001.777] of_register: registering i2c_bus_driver to of_hal
[0001.783] of_register: registering i2c_bus_driver to of_hal
[0001.788] pmic framework initialized
[0001.792] of_register: registering max77620_pmic to of_hal
[0001.797] regulator framework initialized
[0001.801] of_register: registering tps65132_bl_driver to of_hal
[0001.807] initializing target
[0001.813] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.821] board ID = D78, board SKU = 0
[0001.825] Skipping Z3!
[0001.829] fixed regulator driver initialized
[0001.847] initializing OF layer
[0001.850] NCK carveout not present
[0001.853] Skipping dts_overrides
[0001.858] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.875] I2C Bus Init done
[0001.877] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.888] I2C Bus Init done
[0001.890] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.901] I2C Bus Init done
[0001.903] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.914] I2C Bus Init done
[0001.916] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.927] I2C Bus Init done
[0001.929] of_children_init: Ops found for compatible string maxim,max77620
[0001.940] max77620_init using irq 118
[0001.945] register ‘maxim,max77620’ pmic
[0001.949] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.955] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.966] I2C Bus Init done
[0001.969] NCK carveout not present
[0001.979] Find /i2c@7000c000’s alias i2c0
[0001.983] get eeprom at 1-a0, size 256, type 0
[0001.992] Find /i2c@7000c500’s alias i2c2
[0001.996] get eeprom at 3-a0, size 256, type 0
[0002.000] get eeprom at 3-ae, size 256, type 0
[0002.005] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.010] I2C slave not started
[0002.013] I2C write failed
[0002.016] Writing offset failed
[0002.019] eeprom_init: EEPROM read failed
[0002.023] pm_ids_update: eeprom init failed
[0002.027] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.057] pm_ids_update: The pm board id is 3448-0002-400
[0002.064] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.072] pm_ids_update: pm id update successful
[0002.077] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.107] pm_ids_update: The pm board id is 3449-0000-400
[0002.113] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.121] pm_ids_update: pm id update successful
[0002.151] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.157] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.165] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.171] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.179] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:ce:b4
[0002.185] Plugin Manager: Parse ODM data 0x000a4000
[0002.198] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7
[0002.213] Find /i2c@7000c000’s alias i2c0
[0002.216] get eeprom at 1-a0, size 256, type 0
[0002.225] Find /i2c@7000c500’s alias i2c2
[0002.229] get eeprom at 3-a0, size 256, type 0
[0002.234] get eeprom at 3-ae, size 256, type 0
[0002.238] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.243] I2C slave not started
[0002.246] I2C write failed
[0002.249] Writing offset failed
[0002.252] eeprom_init: EEPROM read failed
[0002.256] pm_ids_update: eeprom init failed
[0002.260] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.290] pm_ids_update: The pm board id is 3448-0002-400
[0002.296] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.303] pm_ids_update: pm id update successful
[0002.308] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.338] pm_ids_update: The pm board id is 3449-0000-400
[0002.344] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.351] pm_ids_update: pm id update successful
[0002.382] Add serial number:1423019113295 as DT property
[0002.389] Applying platform configs
[0002.396] platform-init is not present. Skipping
[0002.401] calling apps_init()
[0002.406] Couldn’t find GPT header
[0002.411] Proceeding to Cold Boot
[0002.414] starting app android_boot_app
[0002.418] Device state: unlocked
[0002.421] display console init
[0002.429] could not find regulator
[0002.433] hdmi cable connected
[0002.448] edid read success
[0002.463] edid DT entry for leds-pwm not found
r[0002.471] ead success
[0002.473] width = 640, height = 480, frequency = 25174825
[0002.479] width = 640, height = 480, frequency = 25174825
[0002.484] width = 640, height = 480, frequency = 25174825
[0002.489] width = 1920, height = 1080, frequency = 148500000
[0002.495] width = 1280, height = 720, frequency = 74250000
[0002.500] width = 1920, height = 1080, frequency = 148351648
[0002.506] width = 1280, height = 720, frequency = 74175824
[0002.512] width = 1920, height = 1080, frequency = 148351648
[0002.517] width = 1280, height = 720, frequency = 74175824
[0002.523] width = 720, height = 576, frequency = 26973026
[0002.528] width = 720, height = 480, frequency = 26973026
[0002.533] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.541] tmds-config node not found
[0002.545] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltageps
[0002.560] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.568] could not find regulator
[0002.571] could not find regulator
[0002.574] could not find regulator
[0002.603] using default cmu settings
[0002.606] dc_hdmi_enable, starting HDMI initialisation
[0002.612] dc_hdmi_enable, HDMI initialisation complete
[0002.617] list and configure display window
[0002.626] display console init completed
[0002.637] subnode volume_up is not found !
[0002.641] subnode back is not found !
[0002.645] subnode volume_down is not found !
[0002.649] subnode menu is not found !
[0002.653] Gpio keyboard init success
[0002.733] found decompressor handler: lz4-legacy
[0002.748] decompressing blob (type 1)…
[0002.817] load_bmp_blob: panelresolution=1080 type=3
[0002.892] decompressor handler not found
[0002.896] load_firmware_blob: Firmware blob loaded, entries=2
[0002.902] XUSB blob version 0 size 124416 @ 0x934ae28c
[0002.908] -------> se_aes_verify_sbk_clear: 747
[0002.912] se_aes_verify_sbk_clear: Error
[0002.916] SE operation failed
[0002.919] bl_battery_charging: connected to external power supply
[0002.931] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.938] MSC Partition not found
[0002.945] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.952] USP partition read failed!
[0002.955] blob_init: blob-partition USP header read failed
[0002.961] android_boot Unable to update recovery partition
[0002.966] kfs_getpartname: name = LNX
[0002.970] Loading kernel from LNX
[0002.979] Found 19 BFS partitions in “spiflash0”
[0003.299] load kernel from storage
[0003.304] decompressor handler not found
[0003.569] Successfully loaded kernel and ramdisk images
[0003.574] board ID = D78, board SKU = 0
[0003.579] sdmmc node status = okay
[0003.582] sdcard instance = 0
[0003.585] sdcard gpio handle 0x5b
[0003.588] sdcard gpio pin 0xc9
[0003.591] sdcard gpio flags 0x0
[0003.594] vmmc-supply 0x9e
[0003.597] cd_gpio_pin = 201
[0003.599] pin_state = 0
[0003.602] Found sdcard
[0003.604] SD-card IS present …
[0003.607] load_and_boot_kernel: SD card detected OK
[0003.613] load_bmp_blob: panelresolution=1080 type=3
[0004.107] display bmp image done
[0004.110] NCK carveout not present
[0004.113] Skipping dts_overrides
[0004.117] NCK carveout not present
[0004.126] Find /i2c@7000c000’s alias i2c0
[0004.130] get eeprom at 1-a0, size 256, type 0
[0004.139] Find /i2c@7000c500’s alias i2c2
[0004.143] get eeprom at 3-a0, size 256, type 0
[0004.148] get eeprom at 3-ae, size 256, type 0
[0004.152] pm_ids_update: Updating 1,a0, size 256, type 0
[0004.157] I2C slave not started
[0004.160] I2C write failed
[0004.163] Writing offset failed
[0004.166] eeprom_init: EEPROM read failed
[0004.170] pm_ids_update: eeprom init failed
[0004.174] pm_ids_update: Updating 3,a0, size 256, type 0
[0004.204] pm_ids_update: The pm board id is 3448-0002-400
[0004.211] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0004.219] pm_ids_update: pm id update successful
[0004.224] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.254] pm_ids_update: The pm board id is 3449-0000-400
[0004.260] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0004.268] pm_ids_update: pm id update successful
[0004.298] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.304] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0004.312] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.318] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0004.326] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:ce:b4
[0004.333] Plugin Manager: Parse ODM data 0x000a4000
[0004.345] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7
[0004.353] Add serial number:1423019113295 as DT property
[0004.362] “bpmp” doesn’t exist, creating
[0004.368] Updated bpmp info to DTB
[0004.373] Updated initrd info to DTB
[0004.376] “proc-board” doesn’t exist, creating
[0004.382] Updated board info to DTB
[0004.386] “pmu-board” doesn’t exist, creating
[0004.392] Updated board info to DTB
[0004.395] “display-board” doesn’t exist, creating
[0004.401] Updated board info to DTB
[0004.404] “reset” doesn’t exist, creating
[0004.409] Updated reset info to DTB
[0004.412] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype
[0004.452] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.457] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[0004.470] Updated bootarg info to DTB
[0004.474] Adding uuid 000000016445c84918000000180283c0 to DT
[0004.480] Adding eks info 0 to DT
[0004.485] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.491] Updated memory info to DTB
[0004.499] set vdd_core voltage to 1075 mv
[0004.503] setting ‘vdd-core’ regulator to 1075000 micro volts
[0004.509] Found secure-pmc; disable BPMP
U-Boot 2020.04-g6b630d64fd (Feb 19 2021 - 08:37:46 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash… SF: Detected mx25u3235f with page size 25B
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
839 bytes read in 25 ms (32.2 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7159841 bytes read in 334 ms (20.4 MiB/s)
Retrieving file: /boot/Image
34338824 bytes read in 1523 ms (21.5 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resiz
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 000000008317e68d
copying carveout for /host1x@50000000/dc@54200000…
copying carveout for /host1x@50000000/dc@54240000…
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5294-d8000) (1
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92ca9000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_B
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_B
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nt
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id t
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible s
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa4
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M sect
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29256(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 byte)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3560376K/4159488K available (15294K kernel code, 2942K r)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 )
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 )
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 )
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 )
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 )
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13f808 ( 2943 )
[ 0.000000] .bss : 0xffffff800a13f808 - 0xffffff800a1d7cbc ( 610 )
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 )
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 )
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 )
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 )
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 )
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /intr
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (p.
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398s
[ 0.010075] Console: colour dummy device 80x25
[ 0.014728] console [tty0] enabled
[ 0.018240] bootconsole [uart8250] disabled
[ 0.022567] kmemleak: Kernel memory leak detector disabled
[ 0.022594] Calibrating delay loop (skipped), value calculated using timer f)
[ 0.022616] pid_max: default: 32768 minimum: 301
[ 0.023082] Security Framework initialized
[ 0.023306] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.023323] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.024544] ftrace: allocating 47208 entries in 185 pages
[ 0.195102] ASID allocator initialised with 65536 entries
[ 0.232692] tegra-id: chipid=22117.
[ 0.232723] tegra-id: opt_subrevision=0.
[ 0.232749] Tegra Speedo/IDDQ fuse revision 4
[ 0.232760] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.232771] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.232781] Tegra: CPU Speedo Value 2078, SoC Speedo Value 1996, GPU Speedo 3
[ 0.232793] Tegra: CPU IDDQ Value 2616, SoC IDDQ Value 2764, GPU IDDQ Value 5
[ 0.232820] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.232841] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9s
[ 0.232862] DTB Build time: Feb 19 2021 08:42:41
[ 0.281337] CPU1: Booted secondary processor [411fd071]
[ 0.313244] CPU2: Booted secondary processor [411fd071]
[ 0.345202] CPU3: Booted secondary processor [411fd071]
[ 0.345301] Brought up 4 CPUs
[ 0.345355] SMP: Total of 4 processors activated.
[ 0.345373] CPU features: detected feature: 32-bit EL0 Support
[ 0.345650] CPU: All CPU(s) started at EL2
[ 0.345679] alternatives: patching kernel code
[ 0.354145] devtmpfs: initialized
[ 0.393896] Initilizing CustomIPI irq domain
[ 0.394345] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[ 0.394386] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.405947] pinctrl core: initialized pinctrl subsystem
[ 0.406582] OS set in device tree is not L4T.
[ 0.407026] regulator-dummy: no parameters
[ 0.407322] Initializing plugin-manager
[ 0.407488] Plugin module not found
[ 0.407690] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[ 0.408240] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[ 0.408705] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[ 0.409484] node /plugin-manager/fragement@7 match with odm-data enable-pmict
[ 0.409731] node /plugin-manager/fragement@8 match with odm-data enable-pmict
[ 0.410346] node /plugin-manager/fragement@10 match with board >=3448-0002-30
[ 0.412333] node /plugin-manager/fragement@13 match with board >=3448-0002-30
[ 0.416123] NET: Registered protocol family 16
[ 0.417599] pstore: using zlib compression
[ 0.418131] console [pstore-1] enabled
[ 0.418146] pstore: Registered ramoops as persistent store backend
[ 0.418164] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.437357] cpuidle: using governor menu
[ 0.441982] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.443773] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64)
[ 0.443815] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.445978] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atoms
[ 0.448525] Serial: AMBA PL011 UART driver
[ 0.449072] tegra_powergate_init: DONE
[ 0.449105] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9s
[ 0.449141] DTB Build time: Feb 19 2021 08:42:41
[ 0.451229] Tegra reboot handler registered.
[ 0.455980] iommu: Adding device tegra-carveouts to group 0
[ 0.456145] platform tegra-carveouts: domain=ffffffc0f9443498 allocates as[08
[ 0.456530] iommu: Adding device smmu_test to group 1
[ 0.456598] platform smmu_test: domain=ffffffc0f94436d8 allocates as[0]=ffff0
[ 0.457486] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.457557] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.457629] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.457650] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.457685] mc-err: mcerr ops are set to t21x
[ 0.468163] iommu: Adding device 70090000.xusb to group 2
[ 0.468524] iommu: Adding device 70006000.serial to group 3
[ 0.468607] platform 70006000.serial: domain=ffffffc0f945ed98 allocates as[08
[ 0.469075] iommu: Adding device 70006040.serial to group 4
[ 0.469374] iommu: Adding device 70006200.serial to group 5
[ 0.469589] iommu: Adding device sound to group 6
[ 0.469654] platform sound: domain=ffffffc0f94cb318 allocates as[0]=ffffffc00
[ 0.470231] iommu: Adding device 7000d400.spi to group 7
[ 0.470511] iommu: Adding device 7000d600.spi to group 8
[ 0.470834] iommu: Adding device 70410000.spi to group 9
[ 0.471168] iommu: Adding device 50000000.host1x to group 10
[ 0.471472] iommu: Adding device 54080000.vi to group 11
[ 0.471883] iommu: Adding device 54600000.isp to group 12
[ 0.472161] iommu: Adding device 54680000.isp to group 13
[ 0.472452] iommu: Adding device tegradc.0 to group 14
[ 0.472517] platform tegradc.0: domain=ffffffc0f94d7258 allocates as[0]=ffff8
[ 0.476700] platform tegradc.0: IOVA linear map 0x0000000092ca9000(800000)
[ 0.477109] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.477519] iommu: Adding device tegradc.1 to group 15
[ 0.477586] platform tegradc.1: domain=ffffffc0f94d7498 allocates as[0]=ffff0
[ 0.481737] platform tegradc.1: IOVA linear map 0x0000000092ca9000(800000)
[ 0.482144] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.482443] iommu: Adding device 54340000.vic to group 16
[ 0.482661] iommu: Adding device 544c0000.nvenc to group 17
[ 0.482864] iommu: Adding device 54500000.tsec to group 18
[ 0.483076] iommu: Adding device 54100000.tsecb to group 19
[ 0.483293] iommu: Adding device 54480000.nvdec to group 20
[ 0.483495] iommu: Adding device 54380000.nvjpg to group 21
[ 0.484569] iommu: Adding device 546c0000.i2c to group 22
[ 0.484936] iommu: Adding device 57000000.gpu to group 23
[ 0.485007] platform 57000000.gpu: domain=ffffffc0f954b498 allocates as[0]=f8
[ 0.485087] platform 57000000.gpu: domain=ffffffc0f954b498 allocates as[1]=f0
[ 0.485147] platform 57000000.gpu: domain=ffffffc0f954b498 allocates as[2]=f8
[ 0.485200] platform 57000000.gpu: domain=ffffffc0f954b498 allocates as[3]=f0
[ 0.486134] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency .
[ 0.486175] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.486202] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.486221] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.486238] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.537537] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registerd
[ 0.537569] tegra-pmc: Clear bootloader IO dpd settings
[ 0.537606] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.537680] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reses
[ 0.538002] iommu: Adding device 70012000.se to group 24
[ 0.538793] iommu: Adding device 7000c000.i2c to group 25
[ 0.539079] iommu: Adding device 7000c400.i2c to group 26
[ 0.539339] iommu: Adding device 7000c500.i2c to group 27
[ 0.539612] iommu: Adding device 7000c700.i2c to group 28
[ 0.539884] iommu: Adding device 7000d000.i2c to group 29
[ 0.540151] iommu: Adding device 7000d100.i2c to group 30
[ 0.540428] iommu: Adding device sdhci-tegra.3 to group 31
[ 0.540500] platform sdhci-tegra.3: domain=ffffffc0f955c618 allocates as[0]=8
[ 0.541478] iommu: Adding device 700d0000.xudc to group 32
[ 0.544731] vdd-ac-bat: 5000 mV
[ 0.545115] vdd-5v0-sys: 5000 mV
[ 0.546130] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.546192] vdd-5v0-hdmi: 5000 mV
[ 0.546594] vdd-1v8-sys: 1800 mV
[ 0.547055] vdd-fan: supplied by vdd-5v0-sys
[ 0.547112] vdd-fan: 5000 mV
[ 0.547511] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.547559] vdd-usb-vbus: 5000 mV
[ 0.548086] vdd-usb-vbus2: 5000 mV
[ 0.586328] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.588864] gpio gpiochip0: gpio-line-names specifies 240 line names but thep
[ 0.590054] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.590089] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.590140] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.590498] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochi)
[ 0.598712] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.599095] SCSI subsystem initialized
[ 0.599685] usbcore: registered new interface driver usbfs
[ 0.599754] usbcore: registered new interface driver hub
[ 0.599848] usbcore: registered new device driver usb
[ 0.601211] random: fast init done
[ 0.603887] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.608607] vdd-core: 600 ↔ 1162 mV at 1075 mV
[ 0.609710] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.612536] vdd-ddr-1v1: 1150 mV
[ 0.616479] vdd-pre-reg-1v35: 1350 mV
[ 0.620478] vdd-1v8: 1800 mV
[ 0.624480] avdd-sys-1v2: 1200 mV
[ 0.628478] vdd-pex-1v0: 1050 mV
[ 0.629185] vddio-sdmmc-ap: 1800 ↔ 3300 mV at 3300 mV
[ 0.629774] max77620-ldo3: at 3100 mV
[ 0.632486] vdd-rtc: 850 ↔ 1100 mV at 1000 mV
[ 0.633052] max77620-ldo5: at 3100 mV
[ 0.636481] vddio-sdmmc3-ap: 1800 ↔ 3300 mV at 2800 mV
[ 0.640476] avdd-1v05-pll: 1050 mV
[ 0.644476] avdd-io-hdmi-dp: 1050 mV
[ 0.647239] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.647571] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpioc)
[ 0.647902] max77620 4-003c: max77620 probe successful
[ 0.650746] media: Linux media interface: v0.10
[ 0.650824] Linux video capture interface: v2.00
[ 0.651832] pps_core: LinuxPPS API ver. 1 registered
[ 0.651860] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[ 0.651903] PTP clock support registered
[ 0.655386] tegra210-emc 7001b000.external-memory-controller: validated EMC e
[ 0.656307] Advanced Linux Sound Architecture Driver Initialized.
[ 0.656988] Bluetooth: Core ver 2.22
[ 0.657056] NET: Registered protocol family 31
[ 0.657072] Bluetooth: HCI device and connection manager initialized
[ 0.657099] Bluetooth: HCI socket layer initialized
[ 0.657119] Bluetooth: L2CAP socket layer initialized
[ 0.657158] Bluetooth: SCO socket layer initialized
[ 0.658972] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.659011] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.659070] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.659097] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.662995] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering pe
[ 0.664320] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.664443] vdd-3v3-sys: 3300 mV
[ 0.664799] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.668566] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.669094] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.669150] vdd-3v3-sd: 3300 mV
[ 0.670337] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.670397] avdd-io-edp-1v05: 1050 mV
[ 0.670862] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.670923] vdd-usb-hub-en: 5000 mV
[ 0.672419] camchar: rtcpu character device driver loaded
[ 0.673219] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.674727] clocksource: Switched to clocksource arch_sys_counter
[ 0.716288] VFS: Disk quotas dquot_6.6.0
[ 0.716459] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.716957] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.717423] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vp0
[ 0.717473] dma-vpr: heap size is not multiple of cma_chunk_size heap_info-)
[ 0.717706] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.717728] dma_declare_coherent_resizable_cma_memory:373: resizable cma heal
[ 0.717754] tegra-carveouts tegra-carveouts: assigned reserved memory node vt
[ 0.717805] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 8
[ 0.717829] tegra-carveouts tegra-carveouts: assigned reserved memory node it
[ 0.717858] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.717878] nvmap_page_pool_init: Total RAM pages: 1008878
[ 0.717894] nvmap_page_pool_init: nvmap page pool size: 126109 pages (492 MB)
[ 0.718007] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.718491] misc nvmap: created heap iram base 0x0000000040001000 size (252K)
[ 0.719551] misc nvmap: created heap vpr base 0x00000000d7000000 size (40960)
[ 0.728123] thermal thermal_zone0: Registering thermal zone thermal_zone0 fom
[ 0.728658] thermal thermal_zone1: Registering thermal zone thermal_zone1 fom
[ 0.729070] thermal thermal_zone2: Registering thermal zone thermal_zone2 fom
[ 0.729380] thermal thermal_zone3: Registering thermal zone thermal_zone3 fom
[ 0.729595] thermal thermal_zone4: Registering thermal zone thermal_zone4 foe
[ 0.729893] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.729915] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.730395] NET: Registered protocol family 2
[ 0.731430] TCP established hash table entries: 32768 (order: 6, 262144 byte)
[ 0.731668] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.732216] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.732396] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.732496] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.732941] NET: Registered protocol family 1
[ 0.733699] RPC: Registered named UNIX socket transport module.
[ 0.733726] RPC: Registered udp transport module.
[ 0.733741] RPC: Registered tcp transport module.
[ 0.733757] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.734037] Trying to unpack rootfs image as initramfs…
[ 1.039411] Freeing initrd memory: 6992K
[ 1.049741] host1x 50000000.host1x: initialized
[ 1.051804] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters ae
[ 1.055216] audit: initializing netlink subsys (disabled)
[ 1.055315] audit: type=2000 audit(0.895:1): initialized
[ 1.056082] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.066117] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.067678] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.068493] 9p: Installing v9fs 9p2000 file system support
[ 1.071991] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[ 1.072160] io scheduler noop registered
[ 1.072471] io scheduler cfq registered (default)
[ 1.075289] gic 702f9000.agic: GIC IRQ controller registered
[ 1.078268] iommu: Adding device 702ef000.adsp to group 33
[ 1.087786] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 1.087976] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.088620] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 =d
[ 1.088652] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT4
[ 1.090335] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane =b
[ 1.090463] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane =b
[ 1.090579] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane =b
[ 1.090844] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane =1
[ 1.090956] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane =4
[ 1.091065] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane =4
[ 1.091172] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane =4
[ 1.091284] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane =4
[ 1.091391] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane =b
[ 1.091495] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane =b
[ 1.097794] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.099665] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.101627] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.103086] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.103459] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.104726] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:e
[ 1.104987] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=0
[ 1.105245] Adding domain tsec-pd to PM domain host1x-pd
[ 1.107678] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.108715] tsec 54500000.tsec: initialized
[ 1.110327] tsec 54100000.tsecb: initialized
[ 1.111133] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.115091] nvdec 54480000.nvdec: initialized
[ 1.116219] Adding domain vic03-pd to PM domain host1x-pd
[ 1.116420] Adding domain msenc-pd to PM domain host1x-pd
[ 1.116595] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.121146] falcon 54340000.vic: initialized
[ 1.122443] falcon 544c0000.nvenc: initialized
[ 1.123862] falcon 54380000.nvjpg: initialized
[ 1.128470] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015F7
[ 1.128551] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.128600] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.128734] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.128848] display board info: id 0xffff, fab 0x0
[ 1.128908] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.128925] generic_infoframe_type: 0x87
[ 1.128941] tegra_cec 70015000.tegra_cec: probed
[ 1.129083] tegradc tegradc.0: DT parsed successfully
[ 1.129152] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with i0
[ 1.129739] tegradc tegradc.0: Bootloader disp_param detected. Detected mode1
[ 1.136916] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 chs
[ 1.141998] tegradc tegradc.0: probed
[ 1.142435] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 chas
[ 1.143975] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check d
[ 1.144039] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initd
[ 1.144883] kfuse 7000fc00.kfuse: initialized
[ 1.146636] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-suppe
[ 1.147778] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.149574] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.149623] vdd-cpu: 708 ↔ 1322 mV at 708 mV
[ 1.150195] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator regid
[ 1.151947] vdd-gpu: applied init 1000000uV constraint
[ 1.151987] vdd-gpu: 708 ↔ 1323 mV at 997 mV
[ 1.152457] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator regid
[ 1.157465] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.157662] No Device Node present for smmu client: serial8250 !!
[ 1.157697] platform serial8250: No iommus property found in DT node, got sw)
[ 1.157783] iommu: Adding device serial8250 to group 35
[ 1.162157] console [ttyS0] disabled
[ 1.162371] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud =a
[ 1.627172] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.031758] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.146747] tegra_cec 70015000.tegra_cec: Can’t find physical addresse.
[ 2.146752] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.436271] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.438288] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.544505] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.544514] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.544519] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.544525] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pr]
[ 2.544530] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.544932] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reg
[ 2.554876] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.554881] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.554892] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64b]
[ 2.554912] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64b]
[ 2.554930] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.554939] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.554945] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.554951] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.555346] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.555352] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.642567] console [ttyS0] enabled
[ 3.643197] Console: switching to colour frame buffer device 240x67
[ 3.644044] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baudT
[ 3.644375] serial-tegra 70006200.serial: RX in PIO mode
[ 3.644460] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baudT
[ 3.645423] [drm] Initialized
[ 3.669447] brd: module loaded
[ 3.680477] loop: module loaded
[ 3.680580] tegra_profiler: version: 1.143, samples/io: 48/28
[ 3.683391] tegra_profiler: auth: init
[ 3.687951] THERMAL EST: found 2 subdevs
[ 3.687956] THERMAL EST num_resources: 0
[ 3.687962] [THERMAL EST subdev 0]
[ 3.687969] [THERMAL EST subdev 1]
[ 3.688449] thermal thermal_zone5: Registering thermal zone thermal_zone5 fot
[ 3.688452] THERMAL EST: thz register success.
[ 3.688616] THERMAL EST: end of probe, return err: 0
[ 3.689733] sd: No Scsi addr parsed to reserve index
[ 3.689764] hisi_sas: driver version v1.6
[ 3.695644] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.696890] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.696898] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (40
[ 3.707088] libphy: Fixed MDIO Bus: probed
[ 3.707768] tun: Universal TUN/TAP device driver, 1.6
[ 3.707771] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.710135] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.710140] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.710201] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.710203] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.710266] igbvf: Intel(R) Gigabit Virtual Function Network Driver - versiok
[ 3.710270] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.710319] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.710322] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.715728] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 3.715758] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.729965] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalide
[ 3.730116] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found ve
[ 3.731030] r8168: This product is covered by one or more of the following p.
[ 3.731086] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@rea
[ 3.731086] This program comes with ABSOLUTELY NO WARRANTY; for details, pl
[ 3.731086] This is free software, and you are welcome to redistribute it u
[ 3.731737] PPP generic driver version 2.4.2
[ 3.731967] PPP BSD Compression module registered
[ 3.731973] PPP Deflate Compression module registered
[ 3.732018] PPP MPPE Compression module registered
[ 3.732026] NET: Registered protocol family 24
[ 3.732107] usbcore: registered new interface driver r8152
[ 3.732154] usbcore: registered new interface driver asix
[ 3.732216] usbcore: registered new interface driver ax88179_178a
[ 3.732253] usbcore: registered new interface driver cdc_ether
[ 3.732296] usbcore: registered new interface driver net1080
[ 3.732332] usbcore: registered new interface driver cdc_subset
[ 3.732362] usbcore: registered new interface driver zaurus
[ 3.732414] usbcore: registered new interface driver cdc_ncm
[ 3.732600] VFIO - User Level meta-driver version: 0.3
[ 3.733961] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.734015] ehci-pci: EHCI PCI platform driver
[ 3.734062] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.734073] ohci-pci: OHCI PCI platform driver
[ 3.734125] ohci-platform: OHCI generic platform driver
[ 3.736995] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.737617] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.738853] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9105c00 id
[ 3.741221] usbcore: registered new interface driver uas
[ 3.741280] usbcore: registered new interface driver usb-storage
[ 3.741406] usbcore: registered new interface driver usbserial
[ 3.741783] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:5e
[ 3.741835] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.741862] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus n1
[ 3.742637] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100
[ 3.742697] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 3.742998] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.743005] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[ 3.743010] usb usb1: Product: xHCI Host Controller
[ 3.743013] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 3.743016] usb usb1: SerialNumber: 70090000.xusb
[ 3.743733] hub 1-0:1.0: USB hub found
[ 3.743782] hub 1-0:1.0: 5 ports detected
[ 3.744455] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.744470] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus n2
[ 3.744625] usb usb2: We don’t know the algorithms for LPM for this host, di.
[ 3.744736] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.744741] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[ 3.744745] usb usb2: Product: xHCI Host Controller
[ 3.744748] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 3.744752] usb usb2: SerialNumber: 70090000.xusb
[ 3.745221] hub 2-0:1.0: USB hub found
[ 3.745260] hub 2-0:1.0: 4 ports detected
[ 3.746077] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 3.746083] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 3.746342] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.748450] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.748463] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 3.748501] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.748789] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.749503] mousedev: PS/2 mouse device common for all mice
[ 3.749614] usbcore: registered new interface driver xpad
[ 3.846866] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 3.847179] usb usb2: usb_suspend_both: status 0
[ 3.880101] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as 0
[ 3.882641] rtc rtc1: alarm rtc device
[ 3.882660] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.882689] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.883371] i2c /dev entries driver
[ 3.885529] i2c i2c-6: Added multiplexed i2c bus 7
[ 3.885889] i2c i2c-6: Added multiplexed i2c bus 8
[ 3.885897] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 3.886698] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.910066] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.910141] imx219 7-0010: imx219_board_setup: error during i2c read probe ()
[ 3.910255] imx219 7-0010: board setup failed
[ 3.910334] imx219: probe of 7-0010 failed with error -121
[ 3.911009] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.934277] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.934349] imx219 8-0010: imx219_board_setup: error during i2c read probe ()
[ 3.934418] imx219 8-0010: board setup failed
[ 3.934479] imx219: probe of 8-0010 failed with error -121
[ 3.936162] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.938985] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.938990] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.939461] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 3.939477] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down whenC
[ 3.939487] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when C
[ 3.939661] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 3.939673] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down whenC
[ 3.939678] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when C
[ 3.939837] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 3.939847] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down whenC
[ 3.939852] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot tee
[ 3.940039] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.940882] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.940940] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.940965] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.940982] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.940991] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.942135] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 3.942155] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device’d
[ 3.942390] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.942423] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling devd
[ 3.942966] parse_throttle_dt_data: Num cap clks = 6
[ 3.942971] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.942985] parse_throttle_dt_data: clk=gpu type=4
[ 3.943013] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.943036] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.943059] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.943063] parse_throttle_dt_data: clk=emc type=3
[ 3.943495] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 3.943644] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 3.943832] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.944731] FAN dev name: pwm-fan
[ 3.944815] FAN:gpio request success.
[ 3.944893] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.945215] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.945386] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.945395] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.945497] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, s2
[ 3.945502] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2,2
[ 3.945506] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=12
[ 3.945509] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=12
[ 3.945513] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=13
[ 3.945518] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=13
[ 3.945521] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=13
[ 3.945525] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=14
[ 3.945529] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=4
[ 3.945533] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=4
[ 3.948605] device-mapper: uevent: version 1.0.3
[ 3.949139] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-m
[ 3.955268] tegra210-cpufreq cpufreq: probe()…completed
[ 3.956062] sdhci: Secure Digital Host Controller Interface driver
[ 3.956063] sdhci: Copyright(c) Pierre Ossman
[ 3.956065] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.956432] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 3.963074] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.963633] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.964825] usbcore: registered new interface driver usbhid
[ 3.964827] usbhid: USB HID core driver
[ 3.966996] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 3.967383] tegra21x_actmon 6000c800.actmon: initialization Completed for thl
[ 3.969248] nvpmodel: initialized successfully
[ 3.970242] usbcore: registered new interface driver snd-usb-audio
[ 3.970296] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.970300] platform snd-soc-dummy: No iommus property found in DT node, got)
[ 3.970316] iommu: Adding device snd-soc-dummy to group 36
[ 3.980845] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/ca0
[ 3.989685] OPE platform probe
[ 3.989772] OPE platform probe successful
[ 3.990046] OPE platform probe
[ 3.990130] OPE platform probe successful
[ 3.998799] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADr
[ 4.013954] tegra-asoc: sound: ADMAIF1 ↔ ADMAIF1 mapping ok
[ 4.014085] tegra-asoc: sound: ADMAIF2 ↔ ADMAIF2 mapping ok
[ 4.014204] tegra-asoc: sound: ADMAIF3 ↔ ADMAIF3 mapping ok
[ 4.014329] tegra-asoc: sound: ADMAIF4 ↔ ADMAIF4 mapping ok
[ 4.014451] tegra-asoc: sound: ADMAIF5 ↔ ADMAIF5 mapping ok
[ 4.014574] tegra-asoc: sound: ADMAIF6 ↔ ADMAIF6 mapping ok
[ 4.014694] tegra-asoc: sound: ADMAIF7 ↔ ADMAIF7 mapping ok
[ 4.014842] tegra-asoc: sound: ADMAIF8 ↔ ADMAIF8 mapping ok
[ 4.014964] tegra-asoc: sound: ADMAIF9 ↔ ADMAIF9 mapping ok
[ 4.015082] tegra-asoc: sound: ADMAIF10 ↔ ADMAIF10 mapping ok
[ 4.026555] u32 classifier
[ 4.026557] Actions configured
[ 4.026627] Initializing XFRM netlink socket
[ 4.027382] NET: Registered protocol family 10
[ 4.028086] NET: Registered protocol family 17
[ 4.028097] NET: Registered protocol family 15
[ 4.028172] bridge: filtering via arp/ip/ip6tables is no longer available by.
[ 4.028219] Bluetooth: RFCOMM socket layer initialized
[ 4.028227] Bluetooth: RFCOMM ver 1.11
[ 4.028232] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.028236] Bluetooth: HIDP socket layer initialized
[ 4.028255] 9pnet: Installing 9P2000 support
[ 4.028289] Key type dns_resolver registered
[ 4.031393] Registered cp15_barrier emulation handler
[ 4.031401] Registered setend emulation handler
[ 4.032450] registered taskstats version 1
[ 4.033046] Adding domain ve2-pd to PM domain host1x-pd
[ 4.033285] Adding domain ve-pd to PM domain host1x-pd
[ 4.074793] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.104301] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 4.104305] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.104307] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 4.104309] usb 1-2: Manufacturer: Generic
[ 4.105311] hub 1-2:1.0: USB hub found
[ 4.106285] hub 1-2:1.0: 4 ports detected
[ 4.215115] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 4.230781] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 4.243553] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 4.243556] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.243559] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 4.243561] usb 2-1: Manufacturer: Generic
[ 4.247316] hub 2-1:1.0: USB hub found
[ 4.248090] hub 2-1:1.0: 4 ports detected
[ 4.250782] usb 1-2: usb_suspend_both: status 0
[ 4.250864] usb usb1: usb_suspend_both: status 0
[ 4.398735] usb 2-1: usb_suspend_both: status 0
[ 4.398871] usb usb2: usb_suspend_both: status 0
[ 5.063965] tegradc tegradc.0: fb registered
[ 5.073026] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mod.
[ 5.080266] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hm
[ 5.088672] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 5.095811] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 5.128617] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 5.134734] Extcon AUX1(HDMI) enable
[ 5.138743] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 5.145141] tegradc tegradc.1: No lt-data, using default setting
[ 5.151167] tegradc tegradc.1: No hpd-gpio in DT
[ 5.155799] tegradc tegradc.1: DT parsed successfully
[ 5.160869] tegradc tegradc.1: Display dc.ffffff800d500000 registered with i1
[ 5.168972] tegradc tegradc.1: dpd enable lookup fail:-19
[ 5.171421] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:14
[ 5.188995] tegradc tegradc.1: probed
[ 5.192892] tegradc tegradc.1: fb registered
[ 5.200279] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 5.204015] isp 54600000.isp: initialized
[ 5.204793] isp 54680000.isp: initialized
[ 5.215207] last reset is due to power on reset
[ 5.215210] KERNEL: PMC reset status reg: 0x0
[ 5.215267] BL: PMC reset status reg: 0x0
[ 5.215269] BL: PMIC poweroff Event Recorder: 0x40
[ 5.216785] clk_cbus_recalc_rate: no gbus parent
[ 5.216790] clk_cbus_round_rate: no gbus parent
[ 5.216791] clk_cbus_round_rate: no gbus parent
[ 5.216798] clk_cbus_recalc_rate: no gbus parent
[ 5.216895] clk_cbus_recalc_rate: no gbus parent
[ 5.216898] clk_cbus_round_rate: no gbus parent
[ 5.216899] clk_cbus_round_rate: no gbus parent
[ 5.216902] clk_cbus_recalc_rate: no gbus parent
[ 5.216916] tegra_dvfs: GPU-cap: registered
[ 5.216976] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200d
[ 5.216979] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 1250d
[ 5.216980] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000d
[ 5.265363] tegra_dvfs: vdd-gpu-vts: registered
[ 5.300226] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cd
[ 5.300834] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap coolid
[ 5.301308] input: gpio-keys as /devices/gpio-keys/input/input1
[ 5.328705] hpd: switching from state 7 (Takeover from bootloader) to state )
[ 5.339681] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 5.345192] tegradc tegradc.1: blank - powerdown
[ 5.349809] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00)
[ 5.350842] vi 54080000.vi: vi_probe: ++
[ 5.362518] extcon-disp-state extcon:disp-state: cable 44 state 0 already se.
[ 5.369747] Extcon DP: HPD disabled
[ 5.373245] hpd: hpd_switch 0
[ 5.376220] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 5.382857] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 5.388792] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.397209] vi 54080000.vi: initialized
[ 5.403114] vi 54080000.vi: subdev nvcsi–2 bound
[ 5.407925] vi 54080000.vi: subdev nvcsi–1 bound
[ 5.412679] tegradc tegradc.0: blank - powerdown
[ 5.414190] Disable partitions left on by BL
[ 5.414192] disb
[ 5.414239] bwmgr: missing cdev-type property
[ 5.414366] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 5.414372] DRAM derating cdev registered.
[ 5.415295] ALSA device list:
[ 5.415298] #0: tegra-hda at 0x70038000 irq 83
[ 5.415300] #1: tegra-snd-t210ref-mobile-rt565x
[ 5.460807] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 5.460809] Extcon AUX1(HDMI) disable
[ 5.488748] tegradc tegradc.0: unblank
[ 5.524706] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:10
[ 5.524754] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hm
[ 5.525737] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 5.560418] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 5.560420] Extcon AUX1(HDMI) enable
[ 5.576013] tegradc tegradc.0: sync windows ret = 246
[ 5.732014] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 5.732015] Extcon HDMI: HPD enabled
[ 5.732027] tegradc tegradc.0: hdmi: plugged
[ 5.755318] Freeing unused kernel memory: 8576K
[ 5.786267] Root device found: mmcblk0p1
[ 5.982790] tegra-xusb 70090000.xusb: entering ELPG
[ 5.990692] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, spe3
[ 6.000246] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, spe0
[ 6.011257] tegra-xusb 70090000.xusb: entering ELPG done
[ 15.947060] ERROR: mmcblk0p1 not found
[ 33.282780] random: crng init done
[ 35.966925] vdd-fan: disabling
[ 35.971929] vdd-usb-vbus: disabling
[ 35.977397] vdd-usb-vbus2: disabling
[ 35.982924] vddio-sdmmc-ap: disabling
[ 35.988633] vddio-sdmmc3-ap: disabling
[ 35.994465] vdd-3v3-sd: disabling
[ 35.999710] avdd-io-edp-1v05: disabling
[ 36.005494] vdd-usb-hub-en: disabling
