• Hardware Platform (Jetson / GPU): Jetson AGX Xavier • DeepStream Version: 5.0 • JetPack Version (valid for Jetson only): 4.4.1 • TensorRT Version: 7.1.3 • Issue Type( questions, new requirements, bugs): Bugs • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
I adapt the code from deepstream-image-meta-test to my pipeline to save detected objects as images but I kept getting this error:
Error: Object dimensions are out of frame boundary. Object not encoded.
I have follow -up question regarding the first question. Here are the code I used to do the encoding taken from deepstream-image-meta-test sample:
#define save_img FALSE // auto save image?
#define attach_user_meta TRUE
static GstPadProbeReturn
pgie_src_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info, gpointer ctx)
GstBuffer *buf = (GstBuffer *)info->data;
GstMapInfo inmap = GST_MAP_INFO_INIT;
if (!gst_buffer_map(buf, &inmap, GST_MAP_READ))
GST_ERROR("input buffer mapinfo failed");
return GST_FLOW_ERROR;
NvBufSurface *ip_surf = (NvBufSurface *)inmap.data;
gst_buffer_unmap(buf, &inmap);
NvDsObjectMeta *obj_meta = NULL;
NvDsMetaList *l_frame = NULL;
NvDsMetaList *l_obj = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next)
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)(l_frame->data);
guint num_rects = 0;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next)
obj_meta = (NvDsObjectMeta *)(l_obj->data);
num_rects++;
/* Conditions that user needs to set to encode the detected objects of
* interest. Here, by default all the detected objects are encoded.
* For demonstration, we will encode the first object in the frame */
if (num_rects == 1)
NvDsObjEncUsrArgs userData = {0};
/* To be set by user */
userData.saveImg = save_img;
userData.attachUsrMeta = attach_user_meta;
/* Preset */
userData.objNum = num_rects;
/*Main Function Call */
nvds_obj_enc_process(ctx, &userData, ip_surf, obj_meta, frame_meta);
nvds_obj_enc_finish(ctx);
return GST_PAD_PROBE_OK;
[main]
/* Lets add probe to get informed of the meta data generated, we add probe to
* the srd pad of the pgie element, since by that time, the buffer would have
* had got all the nvinfer metadata. */
pgie_src_pad = gst_element_get_static_pad(pgie, "src");
/*Creat Context for Object Encoding */
NvDsObjEncCtxHandle obj_ctx_handle = nvds_obj_enc_create_context();
if (!obj_ctx_handle)
g_print("Unable to create context\n");
return EXIT_FAILURE;
if (!pgie_src_pad)
g_print("Unable to get src pad\n");
else
gst_pad_add_probe(pgie_src_pad, GST_PAD_PROBE_TYPE_BUFFER, pgie_src_pad_buffer_probe, (gpointer)obj_ctx_handle, NULL);
gst_object_unref(pgie_src_pad);
[main]
You need to make sure that your object bbox is in the frame’s area.
After narrowing it down, the error appears whenever nvds_obj_enc_process is called. I can only find the header file for this function but not its implementation so I don’t know what nvds_obj_enc_process does internally to prevent it from throwing error. In the code from deepstream-image-meta-test sample, I didn’t find the code to make “object bbox is in the frame’s area”. Do you mind elaborate on how to make object bbox in the frame’s area?
I was asking about the implementation for nvds_obj_enc_process, not the interface, the link is for the interface which I can find from the header file.
Here is what fixed the issue for me, I attached the pgie_src_pad_buffer_probe probe at tracker’s “src” pad instead of the pgie’s “src” pad. I can’t explain why though.
How do I set the value for userData.objNum? Can I just let nvds_obj_enc_process set that value? What exactly does objNum refer to?
The implementation for nvds_obj_enc_process is not open source. So only API description and sample codes of usage are available.
Can you reproduce the problem with deepstream-image-meta-test?
