Error on DLI Example
Hello
I found Error like below on DLi Example
https://courses.nvidia.com/courses/course-v1:DLI+T-FX-05+V1/
Do you have same issue?
Best regards,
Hi @mat-h, I’m forwarding this to the DLI team for help.
Thanks for your patience,
Tom
Updated, appears to be caused by a division by zero in veroviz. Will try to determine the cause of the exception.
@mat-h thank you for raising this issue, the DLI notebook has been fixed and this error should no longer occur.
Thank you very much for your kindness.
I really appreciate your help.
I’d like to check the behavior on below DLI.
But we cannot access DLI resources like below Error message.
I would appreciate if you provide us to use this DLI notebook, again.
Best regards,
@mat-h Hi, I was out of the office and missed this post. Is this still an issue for you? Have you tried emailing dli-help@nvidia.com?
Unfortunately , this problem is not solved.
So, We tried to use NGC Docker sample instead.
Best regards,
