ERROR: OSS and NV packages, Unable to locate package linux-libc-dev:i386
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
[*] NVIDIA DRIVE™ Software 10.0 (Linux)
other DRIVE OS version
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] NVIDIA DRIVE™ AGX Pegasus DevKit (E3550)
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
[*] native Ubuntu 18.04
other
We have the NVIDIA DRIVE™ AGX Pegasus DevKit, We are attempting to download and re-flash software 10 and we are getting the following error, 12:43:30 ERROR: OSS and NV packages - target_image: E: Unable to locate package linux-libc-dev:i386. I have included the full log below.
We have tried uninstall the software and delete contents of /Downloads/nvidia/sdkm_downloads, as well as deleting .nvsdkm file. we also tried updating the sdkmanager it self. But it always stops at the same spot of the target download and gives the mentioned error. Any help would be greatly appreciated.
12:43:25 INFO: OSS and NV packages - target_image: Some host system services are essential for cross development.
12:43:25 INFO: OSS and NV packages - target_image: Detecting necessary services on your system…12:43:25 INFO: OSS and NV packages - target_image: Package lib32z1 is already installed, Setting it to manually installed
12:43:25 INFO: OSS and NV packages - target_image: lib32z1 was already set to manually installed.
12:43:25 INFO: OSS and NV packages - target_image: Package lib32ncurses5 is already installed, Setting it to manually installed
12:43:25 INFO: OSS and NV packages - target_image: lib32ncurses5 was already set to manually installed.
12:43:25 INFO: OSS and NV packages - target_image: Package lib32stdc++6 is already installed, Setting it to manually installed
12:43:26 INFO: OSS and NV packages - target_image: lib32stdc++6 was already set to manually installed.
12:43:26 INFO: OSS and NV packages - target_image: Package isc-dhcp-server is already installed, Setting it to manually installed
12:43:26 INFO: OSS and NV packages - target_image: isc-dhcp-server was already set to manually installed.
12:43:26 INFO: OSS and NV packages - target_image: Package nfs-kernel-server is already installed, Setting it to manually installed
12:43:26 INFO: OSS and NV packages - target_image: nfs-kernel-server was already set to manually installed.
12:43:26 INFO: OSS and NV packages - target_image: Package minicom is already installed, Setting it to manually installed
12:43:27 INFO: OSS and NV packages - target_image: minicom was already set to manually installed.
12:43:27 INFO: OSS and NV packages - target_image: Package resolvconf is already installed, Setting it to manually installed
12:43:27 INFO: OSS and NV packages - target_image: resolvconf was already set to manually installed.
12:43:27 INFO: OSS and NV packages - target_image: Package cpp is already installed, Setting it to manually installed
12:43:27 INFO: OSS and NV packages - target_image: cpp was already set to manually installed.
12:43:27 INFO: OSS and NV packages - target_image: Package gcc is already installed, Setting it to manually installed
12:43:28 INFO: OSS and NV packages - target_image: gcc was already set to manually installed.
12:43:28 INFO: OSS and NV packages - target_image: Package gcc-7-multilib is already installed, Setting it to manually installed
12:43:28 INFO: OSS and NV packages - target_image: gcc-7-multilib was already set to manually installed.
12:43:28 INFO: OSS and NV packages - target_image: Package linux-libc-dev is already installed, Setting it to manually installed
12:43:28 INFO: OSS and NV packages - target_image: linux-libc-dev was already set to manually installed.
12:43:28 INFO: OSS and NV packages - target_image: Package cmake is already installed, Setting it to manually installed
12:43:29 INFO: OSS and NV packages - target_image: cmake was already set to manually installed.
12:43:29 INFO: OSS and NV packages - target_image: Package rsync is already installed, Setting it to manually installed
12:43:29 INFO: OSS and NV packages - target_image: rsync was already set to manually installed.
12:43:29 INFO: OSS and NV packages - target_image: Package mount is already installed, Setting it to manually installed
12:43:29 INFO: OSS and NV packages - target_image: mount was already set to manually installed.
12:43:29 INFO: OSS and NV packages - target_image: Package tar is already installed, Setting it to manually installed
12:43:29 INFO: OSS and NV packages - target_image: tar was already set to manually installed.
12:43:29 INFO: OSS and NV packages - target_image: Non interactive : Installing package linux-libc-dev:i386
12:43:30 INFO: OSS and NV packages - target_image: Reading package lists…
12:43:30 INFO: OSS and NV packages - target_image: Building dependency tree…
12:43:30 INFO: OSS and NV packages - target_image: Reading state information…
12:43:30 ERROR: OSS and NV packages - target_image: E: Unable to locate package linux-libc-dev:i38612:43:30 ERROR: OSS and NV packages - target_image: ERROR: linux-libc-dev:i386 failed to install
12:43:30 INFO: OSS and NV packages - target_image: Non interactive mode on : Triggering exit
12:43:30 INFO: OSS and NV packages - target_image: Exiting.
12:43:30 ERROR: OSS and NV packages - target_image: ERROR: Installation failed.
12:43:30 INFO: OSS and NV packages - target_image: [ Package Install Finished with Error ]
12:43:30 INFO: OSS and NV packages - target_image: [host] [ 544.71 MB used. Disk Avail: 224.39 GB ]
12:43:30 INFO: OSS and NV packages - target_image: [ NV_OSS_AND_NV_PACKAGES_SDK_COMP Install took 16s ]12:43:30 ERROR: OSS and NV packages - target_image: command terminated with error
12:43:30 SUMMARY: OSS and NV packages - target_image: First Error: Unable to locate debian package
Regards
d.baykeda
Dear @d.baykeda,
Could you attach ~/.nvsdkm folder
Dear @SivaRamaKrishnaNV
Thank you for your reply. Per your request I’ve attached the .nvsdkm folder
.nvsdkm.zip (148.1 KB)
Thank you again,
d.baykeda
Dear @d.baykeda,
The issue could be due to system state or network glitches/connection. Is it possible to check with fresh host? Please see SDK Manager Install DRIVE Failure if helps?
hello @SivaRamaKrishnaNV,
Thank you for the reply. I was able to solve the issue by manually downloading the deb file directly from ubuntu here: Ubuntu – Package Download Selection -- linux-libc-dev_4.15.0-192.203_i386.deb and installing it using
sudo apt install.
But I have two additional questions for you. We are implementing our own object detection algorithm using MATLAB. And we are using GPU coder to get the CUDA code.
  1. We are having connectivity issues and we suspect it could be SDK issue (GPU coder is tested on DRIVE SDK 5.0.10.3-12606092) and we have 5.1.6.1. Is there a way to downgrade to the necessary SDK?
  2. Can we compile our cuda code directly on our target using the generated make file?
I am not sure if I should’ve opened another topic but I figured I’ll ask while I have this communication open.
Regards
d.baykeda
Dear @d.baykeda,
Does that mean after manual installation, flashing using sdkmanager was succesful? So sdkmanager could not download the same package from same URL?
It is not supported to Downgrade from DSW 10 to Drive os 5.0.10.3 release.
Yes. CUDA code compilation is possible on target with DRIVE SW 10.0 .
Dear @SivaRamaKrishnaNV,
Thanks for the reply and answers.
To answer you question, Yes, it looked like it was failing to download the package. I am not sure if it was trying to download it from the same URL. I had to do quite a bit of digging to find the package. But after manually installing the package I went back to sdkmanager and retried and it checked downloads, OS Image was ready and I successfully flashed.
Regards
d.baykeda
