08:46:43 ERROR : OSS and NV packages : command terminated with error
08:46:43 ERROR : OSS and NV packages : Install ‘OSS and NV packages’ failure, command < using adapter to install NV_OSS_AND_NV_PACKAGES_SDK_COMP@DDPX to /home//nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_DDPX > terminated with error.
I was able to do this install months ago, but now it is failing. When I manually try to install libbz2-1.0:i386 using apt-get, I get an error saying that it cannot locate that package. I already have libbz2-1.0 installed for my host architecture (amd64). Any ideas how I can fix this?
Thanks for the reply. Here’s the compressed log folder
I can’t install Drive Software version 10 because my host computer is Ubuntu 16.04.DRIVE_Software_9.0_Linux_hyperion.tar.gz.txt (16.5 KB)
Note, I had to change the extension of the .tar.gz file to txt in order to upload it. Just remove the .txt extension and you should be able to decompress it.
Hi @anil.dhurjaty,
you have compressed and attached only the log folder in the ~/.sdkm folder.
can you please compress the whole ~/.sdkm folder and attach it?
(notice that zip files can be attached also)
Sorry about that. Here’s the entire zip archive: nvsdkm.zip.txt (1.7 MB)
Still can’t upload a zip file - I get the following message: Sorry, the file you are trying to upload is not authorized (authorized extensions: jpg, jpeg, png, gif, log, doc, docx, txt, cpp, c, rtf).
I added a .txt extension again to circumvent this.
it seems like a linux related issue.
please try executing the following command: sudo dpkg --add-architecture i386 sudo apt update
and then manually install the package, if this succeeds then try installing normally through SDK Manager.
was Drive Software 9.0 previously installed on the same computer that you are trying to reinstall?
did you uninstall Drive Software 9.0 before reinstalling it?
Thanks for sharing the link. I was able to manually install the package, but when I re-run the installation I get a different error for the same thing (OSS and NV packages):
11:22:18 INFO : OSS and NV packages : verifying checksum of /home//Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.0.2-15191604-oss-minimal-sdk.run
11:22:18 INFO : OSS and NV packages : verifying checksum of /home//Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.0.2-15191604-initramfs.run
11:22:18 INFO : OSS and NV packages : verifying checksum of /home//Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.0.2-15191604-drive-platform-rootfs.run
11:22:18 INFO : OSS and NV packages : Found file /home//Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.0.2-15191604-initramfs.run with correct checksum, skip downloading.
11:22:18 INFO : OSS and NV packages : verifying checksum of /home//Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.0.2-15191604-nv-minimal-sdk.run
11:22:19 INFO : OSS and NV packages : Found file /home//Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.0.2-15191604-oss-minimal-sdk.run with correct checksum, skip downloading.
11:22:19 INFO : OSS and NV packages : verifying checksum of /home//Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.0.2-15191604-oss-src.run
11:22:21 INFO : OSS and NV packages : Found file /home//Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.0.2-15191604-nv-minimal-sdk.run with correct checksum, skip downloading.
11:22:29 INFO : OSS and NV packages : Found file /home//Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.0.2-15191604-drive-platform-rootfs.run with correct checksum, skip downloading.
11:22:58 INFO : OSS and NV packages : Found file /home//Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.0.2-15191604-oss-src.run with correct checksum, skip downloading.
11:22:58 INFO : OSS and NV packages : Download ‘OSS and NV packages’ success
11:23:10 INFO : OSS and NV packages : Start to install ‘OSS and NV packages’
11:23:10 DEBUG : OSS and NV packages : using adapter to install NV_OSS_AND_NV_PACKAGES_SDK_COMP@DDPX to /home//nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_DDPX
11:23:10 INFO : OSS and NV packages : [ Disk Avail:77.99 GB ]
11:23:10 INFO : OSS and NV packages : Using GenericInstaller to Install NV_OSS_AND_NV_PACKAGES_SDK_COMP
11:23:10 INFO : OSS and NV packages : NV_OSS_AND_NV_PACKAGES_SDK_COMP include 5 package
11:23:10 INFO : OSS and NV packages : change working directory to /home//nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_DDPX/DriveSDK
11:23:10 INFO : OSS and NV packages : [ Package Install Started ]
11:23:10 INFO : OSS and NV packages : runfile installer start to install NV_OSS_AND_NV_PACKAGES_SDK_COMP
11:23:10 INFO : OSS and NV packages : .install/ folder from previously installed component exists and is being removed
11:23:10 INFO : OSS and NV packages : exec_command: /home//Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.0.2-15191604-oss-minimal-sdk.run --nox11
11:23:10 INFO : OSS and NV packages : Verifying archive integrity… All good.
11:23:11 INFO : OSS and NV packages : Uncompressing drive-t186ref-linux-5.1.0.2-15191604…
11:23:11 INFO : OSS and NV packages : Installing drive-t186ref-linux tools (root filesystem, compilers)
11:23:11 INFO : OSS and NV packages : Some packaging utilities are essential for proper installation of SDK/PDK.
11:23:11 INFO : OSS and NV packages : Detecting necessary packages on your system…
11:23:11 INFO : OSS and NV packages : Package dpkg-dev is already installed, Setting it to manually installed
11:23:11 INFO : OSS and NV packages : dpkg-dev was already set to manually installed.
11:23:11 INFO : OSS and NV packages : Some host system services are essential for cross development.
11:23:11 INFO : OSS and NV packages : Detecting necessary services on your system…
11:23:11 INFO : OSS and NV packages : Package libbz2-1.0:i386 is already installed, Setting it to manually installed
11:23:11 INFO : OSS and NV packages : libbz2-1.0:i386 was already set to manually installed.
11:23:12 ERROR : OSS and NV packages : command terminated with error
11:23:12 ERROR : OSS and NV packages : Install ‘OSS and NV packages’ failure, command < using adapter to install NV_OSS_AND_NV_PACKAGES_SDK_COMP@DDPX to /home//nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_DDPX > terminated with error.
Seems I can’t win.
I’ve attached the logs - same deal with removing the .txt extension. nvsdkm.zip.txt (2.2 MB)
Haven’t tried a new computer. One is not available to me at this time.
can you please post the output if you execute manually the following: chmod 0755 /home/flir/Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.0.2-15191604-oss-minimal-sdk.run --nox11 /home/flir/Downloads/nvidia/sdkm_downloads/drive-t186ref-linux-5.1.0.2-15191604-oss-minimal-sdk.run --nox11
Do you accept the terms of this license? yes/no? yes
ERROR: Installation failed.
