Please provide the following info:
Hardware Platform: [DRIVE AGX Pegasus™ Developer Kit]
Software Version: [DRIVE Software 10]
Host Machine Version: [native Ubuntu 18.04]
SDK Manager Version: [1.3]
docker version: 19.03.13
nvidia-container-toolkit installed
I tried to use docker image with GPU on Pegasus.
I installed docker & nvidia-container-toolkit just after flashing.
But the follow error occurs.
Becuase cuda is installed during flashing, the nvidia driver should have to be installed.
But I cannot find the driver and nvidia-smi is unavailable.
Do I have to install Nvidia drivers for GPU ? How to use the GPU?
nvidia@tegra-ubuntu:~$ sudo docker run --rm --gpus all nvidia/cuda:11.0-base nvidia-smi
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused “process_linux.go:449: container init caused “process_linux.go:432: running prestart hook 0 caused \“error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: driver error: failed to process request\\n\”””: unknown.
Dear @Liang_Qi,
There is no nvidia-smi tool on DRIVE AGX. You can check running deviceQuery CUDA sample(cross compile the sample on host) to know GPU details
It is already part of DRIVE SW. You can write/run some CUDA samples to check running apps on GPU.
Thanks @SivaRamaKrishnaNV.
So could you tell me how to solve the error in my first post?
Dear @Liang_Qi,
Could you check if the discussion on Docker exec fails on xavier helps?
I checked the post, but it seems different to my problem.
I can run docker hello-world with no problem.
But when I tried to run docker image using GPU, the error occurs.
I installed docker following the link https://docs.docker.com/engine/install/ubuntu/
and installed nvidia-container-toolkit with the following commands.
distribution=$(. /etc/os-release;echo $ID$VERSION_ID)
curl -s -L https://nvidia.github.io/nvidia-docker/gpgkey | sudo apt-key add -
curl -s -L https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list | sudo tee /etc/apt/sources.list.d/nvidia-docker.list
sudo apt-get update && sudo apt-get install -y nvidia-container-toolkit
sudo systemctl restart docker
