2024-09-18 03:18:34 [5,628ms] [Error] [carb.scripting-python.plugin] UnicodeDecodeError: ‘gbk’ codec can’t decode byte 0xa0 in position 1096: illegal multibyte sequence
At:
E:\omniverse\pkg\isaac-sim-4.1.0\kit\python\lib\json_init_.py(293): load
e:/omniverse/pkg/isaac-sim-4.1.0/exts/omni.isaac.sensor/omni/isaac/sensor/scripts/menu.py(212): init
e:/omniverse/pkg/isaac-sim-4.1.0/exts/omni.isaac.sensor/omni/isaac/sensor/scripts/extension.py(37): on_startup
E:\omniverse\pkg\isaac-sim-4.1.0/kit/kernel/py\omni\ext_impl_internal.py(164): _startup_ext
E:\omniverse\pkg\isaac-sim-4.1.0/kit/kernel/py\omni\ext_impl_internal.py(224): startup
E:\omniverse\pkg\isaac-sim-4.1.0/kit/kernel/py\omni\ext_impl_internal.py(328): startup_extension
PythonExtension.cpp::startup()(2):
E:\omniverse\pkg\isaac-sim-4.1.0/exts/omni.isaac.kit\omni\isaac\kit\simulation_app.py(405): _start_app
E:\omniverse\pkg\isaac-sim-4.1.0/exts/omni.isaac.kit\omni\isaac\kit\simulation_app.py(199): init
E:\omniverse\pkg\isaac-sim-4.1.0\standalone_examples\api\omni.isaac.franka\follow_target_with_ik.py(12):
2024-09-18 03:18:34 [5,628ms] [Error] [omni.ext.plugin] [ext: omni.isaac.sensor-12.7.1] Failed to startup python extension.
File “E:\omniverse\pkg\isaac-sim-4.1.0\standalone_examples\api\omni.isaac.franka\follow_target_with_ik.py”, line 23, in
my_world.reset()
File “e:/omniverse/pkg/isaac-sim-4.1.0/exts/omni.isaac.core/omni/isaac/core/world/world.py”, line 382, in reset
task.set_up_scene(self.scene)
File “e:/omniverse/pkg/isaac-sim-4.1.0/exts/omni.isaac.core/omni/isaac/core/tasks/follow_target.py”, line 65, in set_up_scene
scene.add_default_ground_plane()
File “e:/omniverse/pkg/isaac-sim-4.1.0/exts/omni.isaac.core/omni/isaac/core/scenes/scene.py”, line 279, in add_default_ground_plane
plane = GroundPlane(prim_path=prim_path, name=name, z_position=z_position, physics_material=physics_material)
File “e:/omniverse/pkg/isaac-sim-4.1.0/exts/omni.isaac.core/omni/isaac/core/objects/ground_plane.py”, line 111, in init
collision_prim_path = get_prim_path(
File “e:/omniverse/pkg/isaac-sim-4.1.0/exts/omni.isaac.core/omni/isaac/core/utils/prims.py”, line 612, in get_prim_path
return prim.GetPath()
AttributeError: ‘NoneType’ object has no attribute ‘GetPath’
How do I fix it?
