I am getting the following error when streaming data from a camera:
vi 54080000.vi: tegra_channel_error_status(): index=0: TEGRA_VI_CSI_ERROR_STATUS=0x00000004 - bits 3-0: h>,<, w>,<
What does this error mean and what might be causing it?
Could you enable the debug print in csi2_fops.c to check the REG dump.
Hi, Thanks for responding.
I believe I enabled dev_dbg for csi2_fops,c with this command:
echo 'file csi2_fops.c +p' > /sys/kernel/debug/dynamic_debug/control
but it only added three extra messages, non of which were register dumps:
[ 363.878279] vi 54080000.vi: Calibrate csi port 5
[ 363.947901] vi 54080000.vi: cil_settingtime was autocalculated
[ 363.947908] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
I couldn’t see any obvious register dump in that file. Is there something else I should have done?
Have confirm by below command.
root@ubuntu:/sys/kernel/debug/dynamic_debug# cat control | grep -i tegra_csi
/dvs/git/dirty/git-master_linux/kernel/nvidia/drivers/media/platform/tegra/camera/csi/csi2_fops.c:111 [csi2_fops]tegra_csi_status =_ "TEGRA_CSI_PIXEL_PARSER_STATUS 0x%08x\012"
/dvs/git/dirty/git-master_linux/kernel/nvidia/drivers/media/platform/tegra/camera/csi/csi2_fops.c:115 [csi2_fops]tegra_csi_status =_ "TEGRA_CSI_CIL_STATUS 0x%08x\012"
/dvs/git/dirty/git-master_linux/kernel/nvidia/drivers/media/platform/tegra/camera/csi/csi2_fops.c:119 [csi2_fops]tegra_csi_status =_ "TEGRA_CSI_CILX_STATUS 0x%08x\012"
root@ubuntu:/sys/kernel/debug/dynamic_debug# echo file csi2_fops.c +p > control
/dvs/git/dirty/git-master_linux/kernel/nvidia/drivers/media/platform/tegra/camera/csi/csi2_fops.c:111 [csi2_fops]tegra_csi_status =p "TEGRA_CSI_PIXEL_PARSER_STATUS 0x%08x\012"
/dvs/git/dirty/git-master_linux/kernel/nvidia/drivers/media/platform/tegra/camera/csi/csi2_fops.c:115 [csi2_fops]tegra_csi_status =p "TEGRA_CSI_CIL_STATUS 0x%08x\012"
/dvs/git/dirty/git-master_linux/kernel/nvidia/drivers/media/platform/tegra/camera/csi/csi2_fops.c:119 [csi2_fops]tegra_csi_status =p "TEGRA_CSI_CILX_STATUS 0x%08x\012"
I spent a bit of time investigating why no debug info was being output.
The CSI registers are output by the function “tegra_csi_status” in nvidia/drivers/media/platform/tegra/camera/csi/csi2_fops.c. The error I am getting is printed by the function “tegra_channel_error_status” in nvidia/drivers/media/platform/tegra/camera/vi/vi2_fops.c, which does not call “tegra_csi_status”, which explains why the register data is not printed.
I added a call to “tegra_csi_status” and rebuilt the kernel. The output is as follows:
[ 374.294073] vi 54080000.vi: cil_settingtime was autocalculated
[ 374.294079] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 374.294101] vc_mipi 8-001a: imx_set_mode: fmt_width,fmt_height=1440,1080 pix_fmt=0x59455247 ‘GREY’, err=0
[ 374.294109] vc_mipi 8-001a: imx_set_gain: Set gain = 0
[ 374.304001] vc_mipi 8-001a: vmax (HW) = 1130
[ 374.304005] vc_mipi 8-001a: vMax = 1130
[ 374.306435] vc_mipi 8-001a: hmax (HW) = 0
[ 374.306439] vc_mipi 8-001a: h1 = 0
[ 374.306443] vc_mipi 8-001a: 1H units= 196 vMax= 1130 exp_time= 800 us
[ 374.306446] vc_mipi 8-001a: SHS = 934 vMax= 1130 exp_time= 800 us
[ 374.328657] vc_mipi 8-001a: SHS 24bit
[ 374.328662] vc_mipi 8-001a: imx_set_exposure: Set exposure=800
[ 374.328666] vc_mipi 8-001a: imx_set_frame_rate: frame_rate=200
[ 374.328670] vc_mipi 8-001a: imx_set_frame_length : FIXED frame length = 1080 TO 1130
[ 374.437720] vc_mipi 8-001a: imx_start_streaming: sensor_ext_trig=0 flash_output=1, ret=0
[ 374.440738] vi 54080000.vi: tegra_csi_status(): chan->numports=1
[ 374.440743] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 374.440748] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 374.440752] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 374.440758] vi 54080000.vi: tegra_csi_status(): chan->numports=1
[ 374.440761] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 374.440765] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 374.440769] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 374.445836] vi 54080000.vi: tegra_channel_error_status(): index=0: TEGRA_VI_CSI_ERROR_STATUS=0x00000004 - bits 3-0: h>,<, w>,<
[ 374.445840] vi 54080000.vi: tegra_csi_status(): chan->numports=1
[ 374.445844] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
[ 374.445848] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 374.445851] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 374.445857] vi 54080000.vi: tegra_csi_status(): chan->numports=1
[ 374.445860] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 374.445864] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 374.445867] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 374.450950] vi 54080000.vi: tegra_channel_error_status(): index=0: TEGRA_VI_CSI_ERROR_STATUS=0x00000004 - bits 3-0: h>,<, w>,<
[ 374.450954] vi 54080000.vi: tegra_csi_status(): chan->numports=1
[ 374.450958] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080
[ 374.450961] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 374.450964] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 374.450970] vi 54080000.vi: tegra_csi_status(): chan->numports=1
[ 374.450973] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 374.450976] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 374.450979] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
Does this give any hints?
I appreciate the help.
The TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000080 tell short frame. That tell the sensor output size doesn’t as expect(report by driver)
PPA_SHORT_FRAME: Set when CSI-PPA receives a short frame. This bit gets set even if
CSI_PPA_PAD_FRAME specifies that short frames are to be padded to the correct line length.
Hi Shane, Thanks for responding.
Does this mean that I can ignore the error id CSI_PPA_PAD_FRAME is enabled? (I think the driver would need to be modified to do this.)
I would suggest to modify the sensor driver to report less line(height) for it.
This was fixed by reducing the line width.
Thanks for your help.
