Hello, in my version Isaac Sim 2021.2.1, I am unable to enable the extension omni.kit.loop-isaac. I am guessing it is because the default one, omni.kit.loop-default is enabled. I tried disenabling the default one but it was not possible. Since Isaac.python_app is dependent on omni.kit. loop, I removed the line of code stating the dependency, from the script to enable it. I am stating this because I think my error might be connected to it
I want to generate synthetic data files in the kitti format , but when I ran the command on the terminal, I got this error:
I got this error when I ran the command in the npy format
Please, how can this be solved? Thank you so much in advance
