Error while flashing Jetson Orin Using flash.sh
I am trying to flash Jetson Orin using the flash.sh script. Downloaded L4T BSP and Sample RootFS from Jetson Linux 34.1 | NVIDIA Developer
-Host PC is installed with Ubuntu 18.04
Command used while flashing-
sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
Flashing fails with error:
Reading board information failed.
Attached detailed log
orin_flasherror.txt (8.0 KB)
Please help to debug the issue.
Ashik
Is you host able to flash other jetson devices?
Yes. I have been flashing AGX board from the same Host.
Could you also share the uart log when this error happened?
Worked after rebooting the Host system.
