Error while generating synthetic data
Hi, I’m trying to generate dataset using offline pose generation example with custom USD file and getting this error. I hope you can help me:
  File "standalone_examples/replicator/offline_pose_generation/offline_doli_pose_generation.py", line 637, in <module>
    test=args.test,
  File "standalone_examples/replicator/offline_pose_generation/offline_doli_pose_generation.py", line 153, in __init__
    self._setup_world()
  File "standalone_examples/replicator/offline_pose_generation/offline_doli_pose_generation.py", line 348, in _setup_world
    self.writer_helper.save_mesh_vertices(mesh_prim, coord_prim, prim_type, self._output_folder)
  File "/home/cenk/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.replicator.isaac/omni/replicator/isaac/scripts/writers/ycb_video_writer.py", line 184, in save_mesh_vertices
    points = get_mesh_vertices_relative_to(mesh_prim, coord_prim)
  File "/home/cenk/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.core/omni/isaac/core/utils/mesh.py", line 34, in get_mesh_vertices_relative_to
    vertices_tf_row_major = np.pad(vertices, ((0, 0), (0, 1)), constant_values=1.0)
  File "<__array_function__ internals>", line 6, in pad
  File "/home/cenk/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/extscore/omni.kit.pip_archive/pip_prebundle/numpy/lib/arraypad.py", line 743, in pad
    pad_width = _as_pairs(pad_width, array.ndim, as_index=True)
  File "/home/cenk/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/extscore/omni.kit.pip_archive/pip_prebundle/numpy/lib/arraypad.py", line 518, in _as_pairs
    return np.broadcast_to(x, (ndim, 2)).tolist()
  File "<__array_function__ internals>", line 6, in broadcast_to
  File "/home/cenk/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/extscore/omni.kit.pip_archive/pip_prebundle/numpy/lib/stride_tricks.py", line 411, in broadcast_to
    return _broadcast_to(array, shape, subok=subok, readonly=True)
  File "/home/cenk/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/extscore/omni.kit.pip_archive/pip_prebundle/numpy/lib/stride_tricks.py", line 350, in _broadcast_to
    op_flags=['readonly'], itershape=shape, order='C')
ValueError: operands could not be broadcast together with remapped shapes [original->remapped]: (2,2)  and requested shape (0,2)
2023-05-17 14:49:53 [13,962ms] [Warning] [carb.audio.context] 1 contexts were leaked
./python.sh: line 41: 23562 Segmentation fault      (core dumped) $python_exe "$@" $args
There was an error running python
Hi there,
can you share the USD file that causes the issue? Did you check if other USD files are getting the same error, or only this particularone?
Best
I didn’t check with other USD files. I just imported a STL file into Isaac Sim and export as USD file.
dolly.usdc (1.4 MB)
dolly.usd (1.4 MB)
I’ve tried these two files. dolly.usdc exported from Blender and dolly.usd exported from Isaac.
Could you share the changes you did in the script and config file? Thanks!
The only change I made in offline_pose_generation.py:
        # Add the part to train the network on
        part_name = "dolly"
        ref_path = "/home/cenk/Desktop/dolly.usdc"
        prim_type = f"_{part_name[1:]}"
        path = "/World/" + prim_type
        mesh_path = path + "/" + prim_type
        name = "train_part"
Can you check if you get an error if you set the DynamicObject as this:
train_part = DynamicObject(
    usd_path="/home/user/Downloads/dolly.usd",
    prim_path="/World/dolly",
    mesh_path="/World/dolly/_oli3/_oli3",
    name=name,
    position=np.array([0.0, 0.0, 0.0]),
    scale=np.array(config_data["OBJECT_SCALE"]),
    mass=1.0,
The mesh_path needs to point to the mesh asset in the script:
Sorry for the late reply. I tried your way but it still didn’t work, I tried a lot but was able to do it just by editing like the example structure and naming the file _olly.usd.
For example, when I imported the 003_cracker_box model, the file was added as _03_cracker_box to the “World”, but when I imported the dolly.usd file, the file was added as dolly, not "_olly. Because of that i renamed the file to _olly.usd
Thanks for the help.
I am glad you managed to fix the issue. Yes, the script is currently tailored to the naming specifics of the YCB dataset meshes.
