I am trying this tutorial: Isaac Sim: Generating Synthetic Data using Replicator Composer - YouTube
After write my tutorial.yaml
configurarion as following:
# object parameters
flying_objects:
obj_model: Choice(["/home/henry/Projects/omniverse/isaac-sim/composer-workspace/assets/models/warehouse.txt", "/home/henry/Projects/omniverse/isaac-sim/composer-workspace/assets/models/office.txt", "/home/henry/Projects/omniverse/isaac-sim/composer-workspace/assets/models/hospital.txt"])
obj_material: Choice(["/home/henry/Projects/omniverse/isaac-sim/composer-workspace/assets/materials/materials.txt"])
obj_count: Range(15, 30)
obj_size: Uniform(25, 100)
obj_rot: Uniform((0, 0, 0), (360, 360, 360))
obj_horiz_fov_loc: Uniform(-1, 1)
obj_vert_fov_loc: Uniform(-1, 1)
obj_distance: Uniform(400, 1000)
# light parameters
camera_light:
light_color: Uniform((0, 0, 0), (255, 255, 255))
light_count: 1
light_intensity: 100000
light_radius: 50
light_distance: 50
flying_lights:
light_count: Range(1, 3)
light_intensity: Uniform(0, 1000000)
light_radius: 20
light_distance: Uniform(400, 800)
# room parameters
scenario_room_enabled: True
floor_size: 2000
wall_height: 2000
#floor_material: Choice(["/home/henry/Projects/omniverse/isaac-sim/composer-workspace/assets/materials/materials.txt"])
#wall_materials: Choice(["/home/henry/Projects/omniverse/isaac-sim/composer-workspace/assets/materials/materials.txt"])
# camera parameters
camera_coord: Uniform((-500, -500, 30), (500, 500, 200))
camera_rot: Normal((0, 0, 0), (25, 25, 25))
I am getting the following error:
File "tools/composer/src/main.py", line 95, in <module>
composer.generate_scene()
File "/home/henry/.local/share/ov/pkg/isaac_sim-2022.1.1/exts/omni.replicator.composer-1.1.3+lx64.cp37/omni/replicator/composer/src/composer.py", line 165, in generate_scene
render_products = _generate_actual_scene()
File "/home/henry/.local/share/ov/pkg/isaac_sim-2022.1.1/exts/omni.replicator.composer-1.1.3+lx64.cp37/omni/replicator/composer/src/composer.py", line 134, in _generate_actual_scene
self._create_scenario_room(scenario_params)
File "/home/henry/.local/share/ov/pkg/isaac_sim-2022.1.1/exts/omni.replicator.composer-1.1.3+lx64.cp37/omni/replicator/composer/src/composer.py", line 416, in _create_scenario_room
walls = rep.group([wall_1, wall_2, wall_3, wall_4])
AttributeError: module 'omni.replicator.core' has no attribute 'group'
./python.sh: line 40: 55157 Segmentation fault $python_exe "$@" $args
There was an error running python
The version of my Isaac Sim is: 2022.1.1.
