I am observing the following error when running offline_pose_generation.py with a custom object.
This is based on: 6. Offline Pose Estimation Synthetic Data Generation — Omniverse Robotics documentation
File “./d3_offline_pose_generation.py”, line 664, in
test=args.test,
File “./d3_offline_pose_generation.py”, line 155, in init
self._setup_world()
File “./d3_offline_pose_generation.py”, line 366, in _setup_world
self.writer_helper.save_mesh_vertices(mesh_prim, coord_prim, prim_type, self._output_folder)
File “/data/omniverse/library/isaac_sim-2022.2.0/exts/omni.replicator.isaac/omni/replicator/isaac/scripts/writers/ycb_video_writer.py”, line 184, in save_mesh_vertices
points = get_mesh_vertices_relative_to(mesh_prim, coord_prim)
File “/data/omniverse/library/isaac_sim-2022.2.0/exts/omni.isaac.core/omni/isaac/core/utils/mesh.py”, line 36, in get_mesh_vertices_relative_to
vertices_tf_row_major = np.pad(vertices, ((0, 0), (0, 1)), constant_values=1.0)
File “<array_function internals>”, line 6, in pad
File “/data/omniverse/library/isaac_sim-2022.2.0/kit/extscore/omni.kit.pip_archive/pip_prebundle/numpy/lib/arraypad.py”, line 743, in pad
pad_width = _as_pairs(pad_width, array.ndim, as_index=True)
File “/data/omniverse/library/isaac_sim-2022.2.0/kit/extscore/omni.kit.pip_archive/pip_prebundle/numpy/lib/arraypad.py”, line 518, in _as_pairs
return np.broadcast_to(x, (ndim, 2)).tolist()
File “<array_function internals>”, line 6, in broadcast_to
File “/data/omniverse/library/isaac_sim-2022.2.0/kit/extscore/omni.kit.pip_archive/pip_prebundle/numpy/lib/stride_tricks.py”, line 411, in broadcast_to
return _broadcast_to(array, shape, subok=subok, readonly=True)
File “/data/omniverse/library/isaac_sim-2022.2.0/kit/extscore/omni.kit.pip_archive/pip_prebundle/numpy/lib/stride_tricks.py”, line 350, in _broadcast_to
op_flags=[‘readonly’], itershape=shape, order=‘C’)
ValueError: operands could not be broadcast together with remapped shapes [original->remapped]: (2,2) and requested shape (0,2)
2023-02-01 22:38:02 [22,460ms] [Warning] [carb.audio.context] 1 contexts were leaked
/data/omniverse/library/isaac_sim-2022.2.0/python.sh: line 41: 15662 Segmentation fault (core dumped) $python_exe “$@” $args
There was an error running python
I found that this is because the following lines in mesh.py return a 0 length array:
vertices_vec3f = UsdGeom.Mesh(mesh_prim).GetPointsAttr().Get()
vertices = np.array(vertices_vec3f)
This only occurs when running offline_pose_generation.py with the ycb_video writer. If I switch to the DOPE writer, it does not occur. Similarly, if I comment out the call to “writer_helper.save_mesh_vertices()” in offline_pose_generation.py, the error does not occur, and images are generated.
