Error while installing deepstream python apps
• Hardware Platform (Jetson / GPU)- jetson agx xavier
• DeepStream Version-6.1
• TensorRT Version
I am trying to install the deepstream python apps and following the instructions on this page.
Everything went fine until section 2.2. In section 2.3.1 I am unable to execute the following command.
sudo docker run --rm --privileged dockerhub.nvidia.com/multiarch/qemu-user-static --reset -p yes
I am getting the following error. Please help me to resolve this error.
Unable to find image ‘dockerhub.nvidia.com/multiarch/qemu-user-static:latest’ locally
docker: Error response from daemon: Get “https://dockerhub.nvidia.com/v2/”: dial tcp: lookup dockerhub.nvidia.com on 127.0.0.53:53: no such host.
See ‘docker run --help’.
You have already worked on the jetson platform. You can complie it directly without Cross-Compilation. You can compile directly with the following reference:https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/master/bindings#223-example and jump to step 3.
Thank you. I can now run the test apps in python.
