• Hardware Platform : Jetson
• DeepStream Version : 6.1
• JetPack Version (valid for Jetson only) : 5.1
• TensorRT Version : 8.4.1
• Issue Type( questions, new requirements, bugs) : Bugs
I built a jetson docker for one of custom DS application on Jetson. The docker was built on xavier nx with DS-6.1. Can I run this docker on other devices because when running the docker on other devices with DS-5.0 and DS-6.0. I encountered the following errors
(gst-plugin-scanner:10): GStreamer-WARNING **: 01:15:50.154: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcompositor.so': libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
(Argus) Error FileOperationFailed: Connecting to nvargus-daemon failed: No such file or directory (in src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 205)
(Argus) Error FileOperationFailed: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 106)
(gst-plugin-scanner:10): GStreamer-WARNING **: 01:15:50.241: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferaudio.so': libnvmedia_tensor.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:10): GStreamer-WARNING **: 01:15:50.247: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:10): GStreamer-WARNING **: 01:15:50.254: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so': libnvmedia_tensor.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:10): GStreamer-WARNING **: 01:15:50.274: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so': libnvmedia_tensor.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:10): GStreamer-WARNING **: 01:15:50.301: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:10): GStreamer-WARNING **: 01:15:50.319: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libnvmedia_tensor.so: cannot open shared object file: No such file or directory
Error loading nvinfer plugin
Error loading nvosd plugin
My application uses nvinfer and nvosd plugins.
