Error with installing SDK manager
Hi everyone,I received the following warning and processed with the installation by skipping it.
SDK Manager is verifying system readiness to install.
APT repository access for Debian package installation(host).
Apt repository check failure (1. sudo -S apt-get update && sudo -S apt-get check; 2. dpkg --audit).
E: Failed to fetch http://ppa.launchpad.net/tj/bugfixes/ubuntu/dists/focal/InRelease 403 Forbidden [IP: 185.125.190.80 80]
E: The repository ‘http://ppa.launchpad.net/tj/bugfixes/ubuntu focal InRelease’ is not signed.
However, an error occurred, causing the installation to fail. Here is the log for that error.
SDKM_logs_JetPack_6.1_Linux_for_Jetson_Orin_Nano_8GB_2024-11-10_17-09-32.zip (157.4 KB)
That web site works, but I see something unusual which is a bit odd. For reference, this is the base of the URL which introduces the error:
Note that “tj” appears to be an individual’s login. Maybe tj is one of the developers there, maybe not, but you would need his login to use that. I’m guessing this was a repository you added later.
