Executing jetson_clocks does nothing
I have Jetson AGX Xavier. When I execute sudo jetson_clocks nothing happens. I mean the fan does not start and I don’t notice any changes in the performance. Any help?
Below is the content of l4t_dfs.conf after executing sudo jetson_clocks --store
/sys/devices/system/cpu/cpu0/online:1
/sys/devices/system/cpu/cpu1/online:1
/sys/devices/system/cpu/cpu2/online:1
/sys/devices/system/cpu/cpu3/online:1
/sys/devices/system/cpu/cpu4/online:1
/sys/devices/system/cpu/cpu5/online:1
/sys/devices/system/cpu/cpu6/online:1
/sys/devices/system/cpu/cpu7/online:1
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq:2265600
/sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq:2265600
/sys/devices/system/cpu/cpu2/cpufreq/scaling_min_freq:2265600
/sys/devices/system/cpu/cpu3/cpufreq/scaling_min_freq:2265600
/sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq:2265600
/sys/devices/system/cpu/cpu5/cpufreq/scaling_min_freq:2265600
/sys/devices/system/cpu/cpu6/cpufreq/scaling_min_freq:2265600
/sys/devices/system/cpu/cpu7/cpufreq/scaling_min_freq:2265600
/sys/devices/system/cpu/cpu0/cpuidle/state0/disable:1
/sys/devices/system/cpu/cpu0/cpuidle/state1/disable:1
/sys/devices/system/cpu/cpu1/cpuidle/state0/disable:1
/sys/devices/system/cpu/cpu1/cpuidle/state1/disable:1
/sys/devices/system/cpu/cpu2/cpuidle/state0/disable:1
/sys/devices/system/cpu/cpu2/cpuidle/state1/disable:1
/sys/devices/system/cpu/cpu3/cpuidle/state0/disable:1
/sys/devices/system/cpu/cpu3/cpuidle/state1/disable:1
/sys/devices/system/cpu/cpu4/cpuidle/state0/disable:1
/sys/devices/system/cpu/cpu4/cpuidle/state1/disable:1
/sys/devices/system/cpu/cpu5/cpuidle/state0/disable:1
/sys/devices/system/cpu/cpu5/cpuidle/state1/disable:1
/sys/devices/system/cpu/cpu6/cpuidle/state0/disable:1
/sys/devices/system/cpu/cpu6/cpuidle/state1/disable:1
/sys/devices/system/cpu/cpu7/cpuidle/state0/disable:1
/sys/devices/system/cpu/cpu7/cpuidle/state1/disable:1
/sys/class/devfreq/17000000.gv11b/min_freq:1377000000
/sys/class/devfreq/17000000.gv11b/device/railgate_enable:0
/sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked:1
/sys/devices/pwm-fan/target_pwm:0
/sys/devices/pwm-fan/temp_control:1
Not sure what you are experiencing.
sudo jetson_clocks --store would store your current clock settings (should be slow after a fresh reboot). You may use this file saved conf for restoring later with sudo jetson_clocks --restore
If you just want to boost clocks, you would just try:
sudo jetson_clocks
Doesn’t this work out ? No fan spinning ?
hello elmarai_oussama,
we had change the behavior of jetson_clock scripts.
starting from JP-4.4, jetson_clocks no longer sets maximum fan speed by default. please enable --fan option if you prefer the old behavior,
you may also refer to documentation, check Maximizing Jetson Xavier Performance for more details.
thanks
Yes, the fan didn’t work by default when running jetson_clocks, but after adding the option --fan it is now working.
Thanks for your help and support.
