I want to create multiple streams of the same camera and view the video steram simultaneously. I thought multiStream example in argus samples would be a good starting point. But I am unable to create multiple PreviewConsumerThread. When I do that I get runtime error.
Unable to make context current (error 0x3002)
Please point me to an example or let me know how this could be done.
Following is my code
* Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of NVIDIA CORPORATION nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
* PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "Error.h"
#include "EGLGlobal.h"
#include "GLContext.h"
#include "JPEGConsumer.h"
#include "Options.h"
#include "PreviewConsumer.h"
#include "Window.h"
#include "Thread.h"
#include <Argus/Argus.h>
#include <unistd.h>
#include <stdlib.h>
#include <sstream>
#include <iomanip>
using namespace Argus;
namespace ArgusSamples
// Constants.
static const uint32_t DEFAULT_CAPTURE_TIME = 5; // In seconds.
static const Size2D<uint32_t> PREVIEW_STREAM_SIZE(640, 480);
static const uint32_t NUMBER_BURST_CAPTURES = 3;
static const uint32_t DEFAULT_CAMERA_INDEX = 0;
static const Rectangle<uint32_t> DEFAULT_WINDOW_RECT(0, 0, 640, 480);
// Globals and derived constants.
EGLDisplayHolder g_display;
// Debug print macros.
#define PRODUCER_PRINT(...) printf("PRODUCER: " __VA_ARGS__)
struct ExecuteOptions
uint32_t cameraIndex;
uint32_t captureSeconds;
Rectangle<uint32_t> windowRect;
* Argus Producer thread:
* Opens the Argus camera driver, creates two OutputStreams -- one for live
* preview to display and the other to write JPEG files -- and submits capture
* requests. Burst captures are used such that the JPEG stream is only written
* to once for every NUMBER_BURST_CAPTURES captures.
static bool execute(const ExecuteOptions& options)
// Initialize the window and EGL display.
Window &window = Window::getInstance();
window.setWindowRect(options.windowRect.left(), options.windowRect.top(),
options.windowRect.width(), options.windowRect.height());
PROPAGATE_ERROR(g_display.initialize(window.getEGLNativeDisplay()));
// Initialize the Argus camera provider.
UniqueObj<CameraProvider> cameraProvider(CameraProvider::create());
ICameraProvider *iCameraProvider = interface_cast<ICameraProvider>(cameraProvider);
if (!iCameraProvider)
ORIGINATE_ERROR("Failed to get ICameraProvider interface");
printf("Argus Version: %s\n", iCameraProvider->getVersion().c_str());
// Get the camera devices.
std::vector<CameraDevice*> cameraDevices;
iCameraProvider->getCameraDevices(&cameraDevices);
if (cameraDevices.size() == 0)
ORIGINATE_ERROR("No cameras available");
if (cameraDevices.size() <= options.cameraIndex)
ORIGINATE_ERROR("Camera %d not available; there are %d cameras",
options.cameraIndex, (unsigned)cameraDevices.size());
// Use the specified device.
ICameraProperties *iCameraDevice =
interface_cast<ICameraProperties>(cameraDevices[options.cameraIndex]);
if (!iCameraDevice)
ORIGINATE_ERROR("Failed to get camera device properties");
std::vector<Argus::SensorMode*> sensorModes;
iCameraDevice->getBasicSensorModes(&sensorModes);
if (!sensorModes.size())
ORIGINATE_ERROR("Failed to get valid sensor mode list.");
// Create the capture session.
UniqueObj<CaptureSession> captureSession(
iCameraProvider->createCaptureSession(cameraDevices[options.cameraIndex]));
ICaptureSession *iCaptureSession = interface_cast<ICaptureSession>(captureSession);
if (!iCaptureSession)
ORIGINATE_ERROR("Failed to create CaptureSession");
// Create the stream settings and set the common properties.
UniqueObj<OutputStreamSettings> streamSettings(iCaptureSession->createOutputStreamSettings());
IOutputStreamSettings *iStreamSettings = interface_cast<IOutputStreamSettings>(streamSettings);
if (!iStreamSettings)
ORIGINATE_ERROR("Failed to create OutputStreamSettings");
iStreamSettings->setPixelFormat(PIXEL_FMT_YCbCr_420_888);
iStreamSettings->setEGLDisplay(g_display.get());
// Create preview-sized OutputStream that is consumed by the preview (OpenGL) consumer1.
PRODUCER_PRINT("Creating preview output stream\n");
iStreamSettings->setResolution(PREVIEW_STREAM_SIZE);
UniqueObj<OutputStream> previewStream1(
iCaptureSession->createOutputStream(streamSettings.get()));
IStream *iPreviewStream1 = interface_cast<IStream>(previewStream1);
if (!iPreviewStream1)
ORIGINATE_ERROR("Failed to create OutputStream");
PRODUCER_PRINT("Launching preview consumer thread\n");
PreviewConsumerThread previewConsumerThread1(iPreviewStream1->getEGLDisplay(),
iPreviewStream1->getEGLStream());
PROPAGATE_ERROR(previewConsumerThread1.initialize());
PROPAGATE_ERROR(previewConsumerThread1.waitRunning());
// Create preview-sized OutputStream that is consumed by the preview (OpenGL) consumer2.
UniqueObj<OutputStream> previewStream2(
IStream *iPreviewStream2 = interface_cast<IStream>(previewStream2);
if (!iPreviewStream2)
PreviewConsumerThread previewConsumerThread2(iPreviewStream2->getEGLDisplay(),
iPreviewStream2->getEGLStream());
PROPAGATE_ERROR(previewConsumerThread2.initialize());
PROPAGATE_ERROR(previewConsumerThread2.waitRunning());
UniqueObj<OutputStream> previewStream3(
IStream *iPreviewStream3 = interface_cast<IStream>(previewStream3);
if (!iPreviewStream3)
PreviewConsumerThread previewConsumerThread3(iPreviewStream3->getEGLDisplay(),
iPreviewStream3->getEGLStream());
PROPAGATE_ERROR(previewConsumerThread3.initialize());
PROPAGATE_ERROR(previewConsumerThread3.waitRunning());
// Create the capture requests.
UniqueObj<Request> requests[NUMBER_BURST_CAPTURES];
std::vector<const Argus::Request*> requestVec;
for (uint32_t i = 0; i < NUMBER_BURST_CAPTURES; i++)
requests[i] = UniqueObj<Request>(iCaptureSession->createRequest());
IRequest *iRequest = interface_cast<IRequest>(requests[i]);
if (!iRequest)
ORIGINATE_ERROR("Failed to create Request");
requestVec.push_back(requests[i].get());
// Enable the preview stream for every capture in the burst.
iRequest->enableOutputStream(previewStream1.get());
iRequest->enableOutputStream(previewStream2.get());
// iRequest->enableOutputStream(previewStream3.get());
if (iCaptureSession->repeatBurst(requestVec) != STATUS_OK)
ORIGINATE_ERROR("Failed to start repeat burst capture request");
// Wait for CAPTURE_TIME seconds.
PROPAGATE_ERROR(window.pollingSleep(options.captureSeconds));
// Stop the repeating request and wait for idle.
iCaptureSession->stopRepeat();
iCaptureSession->waitForIdle();
// Destroy the output streams (stops consumer threads).
previewStream1.reset();
previewStream2.reset();
// previewStream3.reset();
// Wait for the consumer threads to complete.
PROPAGATE_ERROR(previewConsumerThread1.shutdown());
PROPAGATE_ERROR(previewConsumerThread2.shutdown());
// PROPAGATE_ERROR(previewConsumerThread3.shutdown());
// Shut down Argus.
cameraProvider.reset();
// Cleanup the EGL display
PROPAGATE_ERROR(g_display.cleanup());
PRODUCER_PRINT("Done -- exiting.\n");
return true;
}; // namespace ArgusSamples
int main(int argc, char** argv)
printf("Executing Argus Sample: %s\n", basename(argv[0]));
ArgusSamples::Value<uint32_t> cameraIndex(ArgusSamples::DEFAULT_CAMERA_INDEX);
ArgusSamples::Value<uint32_t> captureTime(ArgusSamples::DEFAULT_CAPTURE_TIME);
ArgusSamples::Value<Rectangle<uint32_t> > windowRect(ArgusSamples::DEFAULT_WINDOW_RECT);
ArgusSamples::Options options(basename(argv[0]));
options.addOption(ArgusSamples::createValueOption
("device", 'd', "INDEX", "Camera index.", cameraIndex));
("duration", 's', "SECONDS", "Capture duration.", captureTime));
("rect", 'r', "WINDOW", "Window rectangle.", windowRect));
if (!options.parse(argc, argv))
return EXIT_FAILURE;
if (options.requestedExit())
return EXIT_SUCCESS;
ArgusSamples::ExecuteOptions executeOptions;
executeOptions.cameraIndex = cameraIndex.get();
executeOptions.captureSeconds = captureTime.get();
executeOptions.windowRect = windowRect.get();
if (!ArgusSamples::execute(executeOptions))
