Extension Search Path - Unable to input custom paths - BUG?
Hi all,
I am not able to input a search path in the extension search path lists. When I double click after clicking on add it doesn’t let me input the path. I have attached a the video. Please let me know if it is a bug or I am unaware of any shortcuts.
Thank you for bringing this to our attention. We have an internal ticket addressing this issue and will provide an update when a fix is available.
In the meantime, you can run Isaac Sim with the--ext-folder PATH flag to add an extension folder to look extensions in.
Exactly same issue happened, os : window11
@nishanthrajkumar1 @rji i used to experience something similar. you should be able to get around it by double clicking faster. the clip below was recorded with Windows 11 and Isaac Sim 5.0
Hi @Simplychenable it works , faster dub click indeed works . thank you so much .
You can try setting
runLoops.main.manualModeEnabled = false
in the apps/isaacsim.exp.full.kit Kit experience file as a temporary workaround.
This setting ensures that UI field interactions (like double-click edits) run in the normal update loop rather than manual mode, which can restore expected behavior in some cases. Please let us know if this resolves the issue on your end.
The fix for this double‑click issue is included in Isaac Sim 6.0 OSS. Please try upgrading to 6.0 and let us know if you still see the problem there.
