I’d like to have multiple entries in a extlinux.conf file and make the selection based on hardware.
My use case is having different cameras plugged in on boot.
So, my ideal way of doing this is I could make i2c queries and then base my selection on that. Is that possible?
Another way could be using gpio.
I’m not really sure where to start. Is this a cboot thing?
You would try to specify various DTs with extlinux.conf such as this for a given label:
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
FDT /boot/tegra194-your-cam-custom.dtb
@Honey_Patouceul I understand I can have multiple entries.The only way I know how to select between them is to enter a number at the prompt.
The question is how can I select between them based on a hardware configuration? My use case is different cameras.
hello bike_works,
you may using plugin manager for device registration. if your camera module has onboard EEPROM and is programmed with a valid camera ID.
thanks
@JerryChang I’m on a xavier NX so this isn’t an option. But, could I use the same approach to query a set of i2c addresses? I’ll have one of only a few cameras so I could maybe use this approach instead of reading eeprom?
Is the plugin manager in cboot or where can I review the code?
hello bike_works,
that’s device tree changes to enable plugin manager,
you may refer to below,
$L4T_Sources/r32.4.3/Linux_for_Tegra/source/public/hardware/nvidia/platform/t19x/common/kernel-dts/t19x-common-modules/tegra194-camera-plugin-manager.dtsi
@JerryChang I can’t just enable plugin manager as my cameras don’t have eeproms. I need to figure out some way to select different dtbs based on a hardware config, e.g., gpio, i2c calls etc.
Your idea of pluginmanger is a good tip if I can figure out how to modify that code.
Where is the code located? Is it part of the kernel, part of cboot?
hello bike_works,
according to CBoot session,
CBoot looks for an extlinux.conf configuration file to load device tree (i.e. kernel-dtb binary) file from FDT entry.
you may have customization to select different device tree while system boot-up.
thanks
