Facing issues in following the tutorial on isaac_ros_rtdetr
I was following the tutorial on
https://nvidia-isaac-ros.github.io/repositories_and_packages/isaac_ros_object_detection/isaac_ros_rtdetr/index.html#quickstart
When I switch on the ros2 run rqt_image_view rqt_image_view /rtdetr_processed_image
rqt_image_viewer I am unable to see anything, I guess the processed image is somehow not getting published
Attaching a video for better explanation !
Hi @personal10 ,
Welcome to the Isaac ROS forum.
Accodring to the video, the realsense node is not loaded:
Could you please help to run below command in the docker to source the built workspace and run the test again?
 cd ${ISAAC_ROS_WS}/ && source install/setup.bash
Regards,
Johnny
