Hey guys, I am using nvidia drive orin. There are some samples provided by driveworks sdk. While executing a sample image capture code, a rendering window with coloured pattern is getting opened. But my usb camera is not getting opened in the window. How can I capture an image with USB camera.
Dear @akshay.tupkar,
Is it like you want to record your USB camera video?
yess @SivaRamaKrishnaNV I want to record a video by using this sample
If you want to record USB camera data, you can use DriveWorks SDK Reference: USB Camera Capture Sample directly. If it does not work for your use case. can you share more details about use case?
I could take a screenshot. But suppose if i want to record a video, is there any way?
@SivaRamaKrishnaNV https://docs.nvidia.com/drive/driveworks-4.0/dwx_image_capture_sample.html
there is a sample which says it can record video but it generates output file in h264 format which shows coloured pattern.
It’s a sample application showcasing the Frame Capture module and has nothing to do with the camera. Please refer to the sample @SivaRamaKrishnaNV mentioned previously.
Thank you so much @VickNV and @SivaRamaKrishnaNV
