Just wanted to let you know that S.Harumoto is not the only one with this problem. Recently, we had the same issue in our system:Orin NX 16GB Module + custom carrier board + L4T 35.3.1.
Here’s how we test it:Power on → Enter the OS and the wireless network is connected → Power off → Power on again in 20 seconds
This is part of the reliability verification of the system. We set the time interval, whether it is on or off, the heat dissipation of the module is also good, and at first, the test process worked well.
About a few hundred cycles later, we met the same issue that S.Harumoto described. orin-nx-bootfail_log.txt (95.1 KB)
I> Task: Program display sticky bits (0x50026a84)
I> Task: Storage device deinit (0x50001eec)
I> Task: SMMU external bypass disable (0x50016a60)
I> Task: SMMU init (0x5001697c)
I> Task: Program GICv3 registers (0x50026ba8)
I> Task: Audit firewall settings (0x50023bd0)
I> Task: Bootchain failure check (0x50002434)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
Please test with rel-35.4.1+ devkit and share us the exact reproduce rate about this issue.
The meaning of " Unhandled Exception in EL3" does not really matter here. It is just like a common erorr log that many could be triggered by many causes.
