Failed to flash Jetson AGX Xavier
09:50:22.043 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_XAVIER_TARGETS - error is: import yaml
09:50:22.043 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_XAVIER_TARGETS: ModuleNotFoundError: No module named 'yaml'
09:50:22.043 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_XAVIER_TARGETS - error is: ModuleNotFoundError: No module named 'yaml'
I’ve found above yaml error in your SDKM log.
Please check if Use sdkmanager to flash the jetson orin nx failed - #27 by fschiffel could help in your case.
Are you using a fused board? (i.e. is the secureboot enabled in your case?)
If so, you have to specify -u and -v options in flash command.
Please try using the following command instead.
$ sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1
