When I use this command ./isaaclab.sh -I, I got this error “FileNotFoundError: Could not find the isaac-sim settings file: .vscode/settings.json”. Then when I browse through the files inside the IsaacLab, I found out that “settings.json” file was missing from the beginning during git clone from “git clone GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim”. Is there any other solutions? Thanks.
Hi there, the settings.json file is part of the Isaac Sim binaries. Please make sure the set up the symlink correctly to your local Isaac Sim directory: Installation using Isaac Sim Binaries — Isaac Lab documentation.
So I have successfully installed the Isaac Lab, however, when I am trying to verifying the installation, I get this error.
Hi, I met the same issue. I’m wondering if you have solved it? Thanks.
Hello, at the moment, I could not find a solution to the Module not found error “omni.kit”, however if you found a solution please give an update, thank you.
Sure. Are you able to run Issac Lab in any other way? I have tried to run with --headless, it’s running without giving any error. But when I try to use streaming client, it showed unknown error and can’t video stream it.
I have not tried it with --headless yet, however, I was not able to run Isaac Lab in general, even the examples given in the documents.
Hi, @NorthTronV .
Have you tried to create the symbolic link of Isaac sim by Installation using Isaac Sim Binaries — Isaac Lab documentation?
ln -s path_to_isaac_sim _isaac_sim
For example: ln -s /home/nvidia/.local/share/ov/pkg/isaac-sim-4.0.0 _isaac_sim
Yes, that works for me however, the only thing that is preventing me from opening Isaac Lab or its example in the document at all is this: https://forums.developer.nvidia.com/t/unable-to-install-isaac-sim-package-for-isaac-lab/295628?u=northtronv
