hello abhimanyu.raju,
you’ll need to enable usb-c port for image flashing,
please also check Jetson AGX Xavier Developer Kit Quick Start Guide for the hardware connections,
thanks
thanks
I am not getting a probing failure error as before, but getting an ECID read failure as shown in the image below
Also, I have connected the USB-C cable next to the buttons as shown in the above shared Quick Start Guide.
I have connected power and entered FORCE RECOVERY mode too.
The SDK manager is really confusing! When I attempt to program the Xavier AGX with flash.sh utility, I get a probe failure
However, I do not see any such probing failure with sdkm logs.
is this a brand new Jetson AGX Xavier devkit, or, you’re having odmfuse before?
This is a brand new board trying to boot for the first time.
are you using a Laptop, or you had setup a virtual machine for the host environment?
Laptop running Ubuntu 16.04 natively
I finally got it going with the suggestion shared in this post.
sudo apt-get remove tlp
Was what was required.
