Failure to flash Orin with cloned system.img
I followed
https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/SD/FlashingSupport.html#to-clone-a-jetson-device-and-flash
to retrieve a clone of APP partition system.img.
I did it twice: from the original rootfs, which results in system.img of size 5.6 GB.
Then I installed nvidia-jetpack and again saved a clone of APP partition - this time it is 23 GB.
Then I tried to flash entire device with the small system.img - it works OK.
But when I tried to flash entire device with the large system.img - it fails.
It shows lines:
[ 443.0871 ] Writing partition APP with system.img [ 23773838668 bytes ]
[ 443.0927 ] [ ] 000%
and freezes. Then, after a long time it shows
Error: Return value 3
Note that if I first flash entire device with the small system.img (successfully)
then I can flash APP partition only with the large system.img (successfully)
but I would like to install entire device at once.
Why flashing with large system.img fails?
These are the steps to reproduce (very reliable):
  1. Prepare a clean rootfs:
    export JETPACK=$HOME/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
    mkdir $JETPACK/rootfs
    cd $JETPACK/rootfs
    sudo tar xpf …/Tegra_Linux_Sample-Root-Filesystem_R35.1.0_aarch64.tbz2
    sudo $JETPACK/apply_binaries.sh
    sudo $JETPACK/tools/l4t_create_default_user.sh -u me -p 00 -n orinX
    Apply patch to nvresizefs.sh file according to
    https://developer.download.nvidia.com/embedded/L4T/r35_Release_v1.0/Jetson_Linux_Release_Notes_r35.1.pdf
    Flash device:
    sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
    Device boots normally
  2. Save clone:
    Enter recovery mode on Orin
    cd $JETPACK
    sudo ./flash.sh -r -k APP -G system_clean.img jetson-agx-orin-devkit mmcblk0p1
  3. Boot device and install nvidia-jetpack
    sudo apt update
    sudo apt upgrade
    sudo apt install nvidia-jetpack
    sync
  4. Save clone:
    cd $JETPACK
    sudo ./flash.sh -r -k APP -G system_full.img jetson-agx-orin-devkit mmcblk0p1
  5. Try to reflash device with clean image:
    cd $JETPACK
    cp system_clean.img bootloader/system.img
    success:
    [ 442.5626 ] Writing partition APP with system.img [ 5650417108 bytes ]
    [ 442.5679 ] […] 100%
    *** The target t186ref has been flashed successfully. ***
  6. Try to reflash device with full image:
    cd $JETPACK
    cp system_full.img bootloader/system.img
    Fails:
    [ 435.5842 ] Writing partition APP with system.img [ 23412348940 bytes ]
    [ 435.5996 ] [ ] 000%
    Freezes and eventually shows error:
  7. If I make full flash with clean image and then separately flash full one, then it works,
    but this adds extra step to flash process, which shuold be avoided:
    cd $JETPACK
    Again Enter recovery mode on Orin
    sudo ./flash.sh -r -k APP jetson-agx-orin-devkit mmcblk0p1
    Now success:
    [ 12.8846 ] Writing partition APP with /home/me/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/system.img [ 23412348940 bytes ]
    [ 12.8858 ] […] 100%
So, why it failed to install full image during full flash?
Thank you
Hi jhnlmn,
Are you using the devkit or custom board?
If you use flash.sh with -r parameter, it means “skip building and reuse existing system.img”. And You use with -k parameter, it means updating APP partition only.
Could you help to provide full flash log and serial console log for further check?
When you run the second command, it would re-generate system.img in bootloader/system.img.
I reproduced it again:
sudo ./flash.sh -r jetson-agx-orin-devkit mmcblk0p1 | tee flash_failed_out_2022_12_08.txt 2>&1
Logs attached
flash_failed_2022_12_08.txt (91.2 KB)
flash_failed_serial_2022_12_08.txt (21.1 KB)
This issue might be caused from rootfs partition size of eMMC not enough.
Please try following command to flash with your system_full.img
$ sudo ./flash.sh -r -S 30GiB jetson-agx-orin-devkit mmcblk0p1
-r -------------------- skip building and reuse existing system.img.
-S <size> ------------- Rootfs size in bytes. Valid only for internal rootdev. KiB, MiB, GiB short hands are allowed, for example, 1GiB means 1024 * 1024 * 1024 bytes.
I tried
still fails:
[ 436.4684 ] Writing partition APP with system.img [ 23616559524 bytes ]
[ 436.4741 ] [ ] 000%
serial:
I> Writing APP partition.
E> NV3P_SERVER: Could not write 1048576 bytes.
Note: this -S 30GiB appears to change bootloader/flash.xml
which was:
59055800320
but now:
32212254720
So, it actually reduced partition size, not increased it.
I also tried
sudo ./flash.sh -r -S 40GiB jetson-agx-orin-devkit mmcblk0p1
sudo ./flash.sh -r -S 50GiB jetson-agx-orin-devkit mmcblk0p1
sudo ./flash.sh -r -S 26GiB jetson-agx-orin-devkit mmcblk0p1
all fail
So, it is not he partition size, but something else is being changed during the first boot,
which makes
work only after device was first flashed with small system.img
What it can be? ( I am using devkit)
Please try to modify allocation_attribute of APP from 0x8 to 0x808:
Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi_sdmmc.xml
<partition name="APP" id="1" type="data">
    <allocation_policy> sequential </allocation_policy>
    <filesystem_type> basic </filesystem_type>
    <size> APPSIZE </size>
    <file_system_attribute> 0 </file_system_attribute>
-   <allocation_attribute> 0x8 </allocation_attribute>
+   <allocation_attribute> 0x808 </allocation_attribute>
And flash again with -r parameter
$ sudo ./flash.sh -r jetson-agx-orin-devkit mmcblk0p1
OK, this works.
Can you explain what allocation_attribute 0x808 means?
The “allocatio_atribute” can be 0x8 or 0x808.
The 0x808 should be used on the partition immediately preceding the secondary GPT on the non-boot device. Once “allocatio_atribute” is set to 0x808, the partition will occupy the remaining the free space in on the device; otherwise, it only occupies the space defined the its size.
It is introduced at
Partition Configuration — <partition> Child Elements
