I backup the image again with the patch added into the script, but it’s still the same.
I observed the two clone.img file size and it seems they are the same. Not sure if this is correct.
so clone.img is the old one. clone1.img is the one i backed up after I added the patch.
And here is the modified script. could you help to see if it’s correct too?
#!/bin/bash
# Copyright (c) 2019-2021, NVIDIA CORPORATION. All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions
# are met:
# * Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# * Redistributions in binary form must reproduce the above copyright
# notice, this list of conditions and the following disclaimer in the
# documentation and/or other materials provided with the distribution.
# * Neither the name of NVIDIA CORPORATION nor the names of its
# contributors may be used to endorse or promote products derived
# from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
# EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
# PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
# CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
# EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
# PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
# PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
# OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# This is a script to resize partition and filesystem on the root partition
# This will consume all un-allocated sapce on SD card after boot.
set -e
function usage()
if [ -n "${1}" ]; then
echo "${1}"
fi
echo "Usage:"
echo "${script_name} [options]"
echo ""
echo "Available options are:"
echo ""
echo " -h | --help"
echo " Show this usage"
echo ""
echo " -c | --check"
echo " Check whether ${script_name} can be used on current platform"
echo ""
echo " -g | --get"
echo " Show APP partition size in MB"
echo ""
echo " -m | --max"
echo " Show APP partition maximum available size in MB"
echo ""
echo " -s <app_size> | --size <app_size>"
echo " Set APP partition size in MB"
echo ""
echo "Without any option means consume all unallocated"
echo "space on SD card."
echo ""
echo "Example:"
echo "${script_name}"
echo "${script_name} -s 16384"
function check_pre_req()
root_dev="$(sed -ne 's/.*\broot=\([^ ]*\)\b.*/\1/p' < /proc/cmdline)"
if [[ "${root_dev}" == *UUID* ]]; then
root_dev="$(/sbin/findfs ${root_dev})"
fi
if [[ "${root_dev}" == /dev/mmcblk* ]] || [[ "${root_dev}" == /dev/sd* ]] \
|| [[ "${root_dev}" == /dev/nvme* ]]; then
block_dev="$(/bin/lsblk -no pkname ${root_dev})"
root_dev="$(echo $root_dev | sed 's/^.....//g')"
fi
if [ "${block_dev}" != "" ]; then
# Check whether APP partition is located at the end of the disk
if ! cat /sys/block/${block_dev}/${root_dev}/start > /dev/null 2>&1 ; then
support_resizefs="false"
return
fi
root_start_sector="$(cat /sys/block/${block_dev}/${root_dev}/start)"
all_start_sectors="$(cat /sys/block/${block_dev}/*/start)"
is_last="true"
for start_sector in ${all_start_sectors}; do
if [[ "${start_sector}" -gt "${root_start_sector}" ]]; then
is_last="false"
break
fi
done
support_resizefs="${is_last}"
fi
if [ "${is_last}" == "true" ]; then
get_app_size
max_available_app_size
size="+${max_app_size}M"
fi
function get_app_size()
partition_size="$(cat /sys/block/${block_dev}/${root_dev}/size)"
cur_app_size="$((partition_size/2/1024))"
function max_available_app_size()
# Move backup GPT header to end of disk
sgdisk --move-second-header "/dev/${block_dev}" > /dev/null 2>&1
app_start_sector="$(cat /sys/block/${block_dev}/${root_dev}/start)"
last_usable_sector="$(sgdisk -p /dev/${block_dev} | \
grep "last usable sector" | \
awk '{print $10}')"
max_app_size="$(((last_usable_sector - app_start_sector + 1)/2/1024))"
function parse_args()
while [ -n "${1}" ]; do
case "${1}" in
-h | --help)
usage
exit 0
-c | --check)
echo "${support_resizefs}"
exit 0
-g | --get)
if [ "${support_resizefs}" = "false" ]; then
echo "ERROR: ${script_name} doesn't support this platform."
exit 1
fi
echo "${cur_app_size}"
exit 0
-m | --max)
exit 1
fi
echo "${max_app_size}"
exit 0
-s | --size)
[ -n "${2}" ] || usage "Not enough parameters"
size="+${2}M"
shift 2
usage "Unknown option: ${1}"
exit 1
esac
done
script_name="$(basename "${0}")"
size="0"
cur_app_size="0"
max_app_size="0"
root_dev=""
block_dev=""
check_pre_req
parse_args "${@}"
exit 1
fi
# Get partition information for root partition
partition_num="$(cat /sys/block/${block_dev}/${root_dev}/partition)"
partition_name="$(sgdisk -i ${partition_num} /dev/${block_dev} | \
grep "Partition name" | cut -d\' -f2)"
partition_type="$(sgdisk -i ${partition_num} /dev/${block_dev} | \
grep "Partition GUID code:" | cut -d' ' -f4)"
partition_uuid="$(sgdisk -i ${partition_num} /dev/${block_dev} | \
grep "Partition unique GUID:" | cut -d' ' -f4)"
partition_attr="$(sgdisk -i ${partition_num} /dev/${block_dev} | \
grep "Attribute flags:" | cut -d' ' -f3)"
# Get start sector of the root partition
# Delete and re-create the root partition
# This will resize the root partition.
sgdisk -d "${partition_num}" \
-n "${partition_num}":"${start_sector}":"${size}" \
-c "${partition_num}":"${partition_name}" \
-t "${partition_num}":"${partition_type}" \
-u "${partition_num}":"${partition_uuid}" \
-A "${partition_num}":=:"${partition_attr}" \
"/dev/${block_dev}"
# Inform kernel and OS about change in partition table and root
# partition size
partprobe "/dev/${block_dev}"
# Resize filesystem on root partition to consume all un-allocated
# space on disk
resize2fs "/dev/${root_dev}"
Some more details. After modifying this script, i rerun
sudo ./apply_binaries.sh
Then I ran this to backup again
sudo ./flash.sh -r -k APP -G clone1.img jetson-agx-orin-devkit mmcblk0p1
Then I copy this clone1.img to bootloader/system.img
Then i ran
sudo ./flash.sh -r jetson-agx-orin-devkit mmcblk0p1
Finally it hangs in the same place
