My app is running in the docker container on the jetson AGX,
after removing and recreating the app docker container over 1000 times. I couldn’t start my app docker container again, the error logs show “create the captureSession failed”, even if I run the multimedia media of 10_camera_recording on the host(not in the docker container), it also shows “create the captureSession failed”.
Then I tried the command below, but it also did not work.
desktop:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 num-buffers=1 ! "video/x-raw(memory:NVMM), format=(string)NV12, width=(int)3840, height=(int)2160" ! nvvidconv ! pngenc ! filesink location=~/cv_cam_0.png
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
(Argus) Error Timeout: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:751 Failed to create CaptureSession
Got EOS from element "pipeline0".
Execution ended after 0:01:00.020096449
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
(Argus) Error InvalidState: Argus client is exiting with 2 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
but the V4l2 can work as expected
desktop:~$ v4l2-ctl -V --set-ctrl bypass_mode=0 --stream-mmap --stream-count=10000000 -d /dev/video0
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 60.00 fps
One thing more:
I monitored argus_socket when the camera worked fine by:nc -l argus_socket
desktop:/tmp$ nc -l argus_socket
nc: getaddrinfo: Servname not supported for ai_socktype
but after removing and recreating the app docker container over 1000 times;
argus_socket: forward host lookup failed: Unknown host
The other interesting thing ,
when the camera worked fine, I ran sudo lsof | grep argus_socket.
here only show two /tmp/argus_socket type=STREAM
here show a lots of /tmp/argus_socket type=STREAM
I tried to kill the process, but I could not kill the process.
