We have been able to root caused the issue, fix is incorporated in driver and will be available in future release.
Shall update once it is available publicly.
amrits
20
Related topics
| Can't control fan speed with beta driver 349.12 | 36 | 29705 | May 19, 2015 | |
| 465.24.02 - No longer able to set Graphics Clock Offset and Memory Transfer Rate Offset | 40 | 21086 | December 8, 2022 | |
| [REGRESSION] [520.56.06][HW DAMAGE] Cannot set fan speed to 0 any longer for Turing/GeForce 1660 Ti | 5 | 1638 | January 24, 2023 | |
| How to set fanspeed in Linux from terminal | 30 | 102532 | January 11, 2025 | |
| Any workaround to the 30% fan speed limitation on newer NVIDIA GPUs? | 8 | 15757 | July 29, 2026 | |
| After adding a second GPU, automatic fan control on first GPU leaves it at 0% always | 6 | 1974 | October 28, 2024 | |
| GT440 fan speed can not be lowered below 50% | 1 | 486 | August 22, 2019 | |
| Setuid bit of "/usr/lib/Xorg" and GPU fan speed | 11 | 2373 | September 6, 2021 | |
| Enable GPU fan settings has no effect | 7 | 10512 | May 10, 2023 | |
| Auto fan speeds with user-controlled lower bounds feature request | 3 | 2822 | October 28, 2024 |
