Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
other
Host Machine Version
native Ubuntu 18.04
other
When trying to do a cross compilation to compile TensorRT sample to run on target (AGX DRIVE). I have the following error :
Here is the path of cuda_runtime_api.h on my host machine :
VickNV
September 8, 2021, 12:54pm
5
Hi @mohammed.el-yaagoubi ,
Did you compile on the host with the host components of DRIVE OS 5.2.0 installed (via SDK Manager)?
Yes and when running make TARGET=aarch64 I have the following error :
VickNV
September 8, 2021, 1:20pm
7
Does your /usr/local/cuda link to correct cuda toolkit path?
$ ls -l /usr/local/cuda
lrwxrwxrwx 1 root root 9 Sep 8 05:17 /usr/local/cuda → cuda-10.2
Didn’t you already clarify a similar problem in Hello World Application on DRIVE AGX ?
I don’t have this file
For that problem I installed cuda once again properly and it worked but now for the cross compilation I have the same error
VickNV
September 8, 2021, 1:40pm
9
You don’t need to install cuda manually. All necessary components were installed in SDK Manager.
Please see if setting the environment variable CUDA_INSTALL_DIR (mentioned in TensorRT Installation Instructions :: DRIVE Platform Installation Guide with NVIDIA SDK Manager ) will help.
Or I would suggest you run through the host component installation of DRIVE OS 5.2.0 in SDK Manager (target isn’t needed) again.
