Feedback and Questions Regarding RTX VSR Improvements and Future RTX Video Features
Hello NVIDIA team
I use RTX Video Super Resolution (RTX VSR) every day for watching local videos (mostly 1080p → 1440p, and soon 1080p → 4K). I want to start by saying thank you — RTX VSR has genuinely improved my viewing experience.
When the source is good (1080p or 720p with a high bitrate), the image on my 1440p monitor with RTX VSR enabled is extremely close to 4K. I even paused the video on the same frame and compared the pixels side‑by‑side, and the difference was almost nonexistent. It’s really impressive.
With lower‑quality sources (YouTube, older videos, low bitrate), VSR doesn’t manage to fix the artifacts as well, so I’m curious whether improvements in this area are planned.
I also want to mention that RTX VSR works very well with high‑quality local sources. With good 1080p WEB‑Rip files or Blu‑ray REMUX videos, the upscaling results are consistently clean and detailed. When playing a 1080p REMUX on a 4K TV at a normal viewing distance, it becomes difficult for most people to tell that the original source is only 1080p. The improvement with VSR enabled is subtle but meaningful, and it brings the image noticeably closer to a native 4K presentation.
I also want to say that I’m honestly impressed by your engineering work. RTX VSR is one of the most useful and impressive AI features I’ve ever used, and I really appreciate the effort behind it. I hope this technology continues to grow, because it has huge potential.
I have two questions I’d really like to ask:
First, are you currently working on new improvements or new AI models for RTX VSR? VSR 1.5 is already great, but there is still room for improvement, especially with low‑quality sources, motion handling, and fine detail reconstruction. I know that RTX VSR already works with AV1 and that RTX Video HDR can run together with VSR, but I’m wondering if future updates might improve the way HDR and VSR interact — especially in scenes where fine details can become slightly over‑brightened. I’m also curious whether higher VSR levels, like Level 5 or even Level 6, are something you’re considering for future releases.
Second, are you planning to add AI frame interpolation to RTX Video?
For example, converting 23.976 fps video to 50 or 60 fps during playback. Since NVIDIA already has Optical Flow Accelerator, DLSS Frame Generation, Maxine Video Effects, and other motion‑related AI technologies, it would be amazing to see real‑time AI FPS interpolation for video playback.
I also have a small suggestion:
It would be great if RTX VSR could be available as an FFmpeg filter or API for offline video processing. Many users would love to use VSR not only during playback, but also for high‑quality offline upscaling (1080p → 4K) with larger AI models.
Thank you again for your work — I use RTX VSR every day and I’m genuinely impressed by it. I’m looking forward to future improvements.
Best regards,
One thing I’d really like to see NVIDIA improve with RTX VSR is its ability to enhance lower-quality video sources in real time.
For example, when watching a good-quality 1080p video on a 4K display, the image can already look surprisingly close to native 4K. However, when watching a heavily compressed 1080p video with a low bitrate, the difference in image quality is very noticeable, even when using RTX VSR.
What I’d really like is for RTX VSR to do a much better job of improving these lower-quality sources, so that a compressed 1080p video could look much closer to a high-bitrate 1080p source when upscaled to 4K.
I’m not talking about offline video restoration or post-processing like Topaz Video AI. I mean something that works directly during playback, in real time.
Ideally, the AI should be able to:
  • Reconstruct details lost due to heavy compression.
  • Improve textures, faces, hair and fine details.
  • Remove compression artifacts and blockiness.
  • Reduce noise and blurry details without making the image look oversharpened.
  • Maintain consistent image quality between frames without flickering.
I would also love to see more advanced AI models and higher quality settings, even if they require more GPU power.
I think this would make RTX VSR much more useful, especially for streaming services and online videos where bitrate and compression can vary significantly.
The goal would be to make a lower-quality 1080p source look as close as possible to a high-quality 1080p source when viewed on a 4K display, while still preserving the original look of the video.
Is NVIDIA considering improvements in this direction for future RTX Video updates?
