Flash jetson OS won't finish
In this case, should I start over again?
Why can’t cleaning up fish?
Is it because the machine specs of the NX developer kit are not good enough?
NX developer kit with MicroSD slot version?
Which JetPack version you flash?
On host PC with native Ubuntu OS or VM?
Target Device is NVMe and SSD that is M Key 250GB WD Blue.
Jetpack version is 4.6.2.
host PC is archlinux on surface.
I used the following docker.
It seems to be failing when try mount to host pc and jetson nx.
host PC is archlinux on surface, with docker?
Sorry to tell that it’s not we suggested system environment, may other developers help to share experience or try with native Ubuntu OS 18.04 for your JetPack 4.6.2.
