Description of the custom board recovery port:
The recovery port is a USB Micro-B (as described in the Nano Series Product Design Guide 7.1 USB Figure 7-1) and not a USB-C port as in the devkit. We use the original device tree from the devkit.
Can the ncm interface mode also be provided via the USB Micro-B socket, i.e. only USB0_D_N/P?
These were the first tests on the new custom board yesterday, I had already thought something like this. I will stick to the description for customizing the device tree →
Thanks for the hint, I will use rel-35.4.1. I will adjust the device tree in the next few days. If there is a difficult question about the device tree, I will contact you again :-)
I have just customized the device tree, now everything works as desired. It was a bit naive of me to flash the new Paltine via the SDK tool :-) Maybe I’ll have another question about the device tree at some point, then I’ll be happy to get back to you.
