Hi;
I’m doing my first steps with Jetson TX2, but flashing the board for the first time fails.
What I have done:
Linux host system is a fresh copy of Ubuntu 16.04.3 LTS amd64 within the most recent VirtualBox release.
I install Jetpack-L4T-3.1-linux-x64.run (35477869 bytes)
I’ve got a Jetson TX1 (yes, TX1) Devkit. I removed the TX1 CPU module/heatsink/fan assembly and mounted a TX2 CPU module (factory new, came unopend and sealed in its antistatic bag) and a new heatsink on top of the TX2. Having read the documentation for TX1 and TX2 I assumed that they are socket compatible.
I connected power and UART0 (via J21), pressed the recovery button and turned the board on. lsusb showed an NVidia device.
I tried both flashing from the installer and issuing “sudo ./flash.sh jetson-tx2 mmcblk0p1”
The flash process quits abnormally:
-------------Last lines of Linux terminal output--------------
[ 3.7667 ] Sending bootloader and pre-requisite binaries
[ 3.7704 ] tegrarcm_v2 --download blob blob.bin
[ 3.7710 ] Applet version 01.00.0000
[ 3.7923 ] Sending blob
[ 3.7923 ] […] 100%
[ 4.2753 ]
[ 4.2762 ] tegrarcm_v2 --boot recovery
[ 4.2768 ] Applet version 01.00.0000
[ 4.2885 ]
[ 4.2987 ] tegrarcm_v2 --isapplet
[ 4.9307 ]
[ 4.9331 ] tegradevflash_v2 --iscpubl
[ 4.9339 ] CPU Bootloader is not running on device.
[ 4.9366 ]
[ 36.4983 ] Retrieving storage infomation
[ 36.5012 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 36.5040 ] Applet is not running on device. Continue with Bootloader
[ 36.5454 ]
[ 36.5554 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 36.5562 ] CPU Bootloader is not running on device.
[ 36.5568 ]
Error: Return value 4
Command tegradevflash_v2 --oem platformdetails storage storage_info.bin
Failed flashing t186ref.
-------------Last lines of UART0 output--------------
[0230.355] I> Boot-device: eMMC
[0230.379] I> sdmmc ddr50 mode
[0230.383] I> sdmmc bdev is already initialized
[0230.387] I> Reading GPT from 512 for device 00000003
[0230.393] I> Reading GPT from 8388096 for device 00000003
[0230.399] W> Cannot find any partition table for 00000003
[0230.404] E> tegrabl_partition_publish: exit error = 6834001
[0230.409] I> Reading GPT from 512 for device 00010003
[0230.415] I> Reading GPT from 31268535808 for device 00010003
[0230.421] W> Cannot find any partition table for 00010003
[0230.427] E> tegrabl_partition_publish: exit error = 6834001
[0230.432] I> Recovery boot_type: 0
[0230.435] I> bl dtb load address = @0x85690000
[0230.442] I> fixed regulator driver initialized
[0230.477] I> register ‘maxim’ power off handle
[0230.483] I> virtual i2c enabled
[0230.486] I> registered ‘maxim,max77620’ pmic
[0230.491] I> tegrabl_gpio_driver_register: register ‘max77620-gpio’ driver
[0230.498] I> Entering 3p server
[0230.501] I> Entering into 3p server..
[0230.504] I> Transport interface is USB
[0230.513] I> setting ‘vdd-3v3-sys’ regulator to 3300000 micro volts
[0230.520] W> tegrabl_usbf_priv_init enable regulator failed
[0230.525] I> tegrabl_usbf_priv_init:2583 full init:: [0230.530] I> SUPER SPEED
I noticed the lines:
My questions:
- Is the DevKit carrier board the same for TX1 and TX2? Should the module swap TX1-TX2 work? Are there incompatible revisions? Please note that the TX1 devkit has been purchased end of 2016 and may predate the TX2 release.
- Did I make any mistake? Did I break anything?
Best Regards
Frank-Christian Kruegel
Embedded Engineer
OptoPrecision GmbH Bremen
