At first the board worked fine with preinstalled Ubuntu, but when i tried to flash Jetson nano production module ,eMMC [setup has custom carrier board from seeds studio Jetson-10-1A0), doesn’t worked with the virtual-box as host Ubuntu, as there was issue with the USB device access inside Virtual box.
Now i am trying with different computer running ubuntu18.04 , but it gets stuck in the the middle (see the command line output attached at the end of this topic)
Although flash would most likely technically still work with a custom carrier board and the default JetPack/SDK Manager, you would still end up with non-functioning parts since the device tree would need customization. To that extent the manufacturer of custom carrier boards will provide its own flash software (mostly a minor edit of the dev kit JetPack/SDK Manager software). So you will probably want to first see if the manufacturer has its own instructions and software.
FYI, the numbering you see in a flash is in part (A) naming the module (if it is the same module), and in other part (B), naming the carrier board. The module portion won’t differ among carrier board manufacturer’s software, but the carrier board portion will change.
I check with manufacture (seedstudio) of custom carrier board, they confirmed the same procedure and JetPack works for flashing there are no modification in device tree.
Should I try with the latest JetPack and see if it works?
Then JetPack probably is ok if they have the same device tree. However, are you still using a VM? A VM can cause flash failure if the USB pass-through is not functioning 100% correct.
The serial UART (not dmesg) has no output? That’s a more serious hardware issue (assuming the right UART is being used). Normally the serial port would be from the dev kit’s micro-OTG USB port. Is that the serial UART port you are using? On the host PC, if you run “dmesg --follow”, and watch as the serial cable (via the micro-OTG port) is plugged in, what do you see?
Are you sure your host machine is able to read the “uart” log on the same board before? Not the log from micro usb port .
It is unlikely that this board just cannot boot and log is empty. If your emmc was never flashed successfully, and that board was “working fine” before, the there should be at least something coming out from the uart. I mean the boot process may not be successful, but the log shall still show something.
I agree that there should be something on uart, even I feel there is something wrong with the hardware.
As we soldered the SD card holder(Not to flash the image in SD , but to use as storage) on Jetson Nano Production Module, before starting the flashing process. I will check if there is anything wrong in soldering.
This is the output of dmesg --follow after disconnecting and connecting again the FTDI serial module
[27836.850237] usb 3-10.1.1: USB disconnect, device number 30
[28403.492901] usb 3-9: USB disconnect, device number 19
[28403.493767] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[28403.493809] ftdi_sio 3-9:1.0: device disconnected
[28656.462968] usb 3-9: new full-speed USB device number 31 using xhci_hcd
[28656.617035] usb 3-9: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
[28656.617039] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[28656.617041] usb 3-9: Product: UMFT234XF
[28656.617043] usb 3-9: Manufacturer: FTDI
[28656.617045] usb 3-9: SerialNumber: FT4MDM3O
[28656.620302] ftdi_sio 3-9:1.0: FTDI USB Serial Device converter detected
[28656.620356] usb 3-9: Detected FT-X
[28656.621076] usb 3-9: FTDI USB Serial Device converter now attached to ttyUSB0
